Author Topic: W5w bulbs  (Read 2186 times)
Offline MR Pap
W5w bulbs
« on: March 31, 2010, 10:11:36 pm »
Does anyone know how too fit w5w bulbs in a xenon housing unit?
Cheers J
When asked "What would the dogs bollocks look like with four wheels" VW designed the golf gti.
Offline WhiteGTI
  • F-A-S-T
Re: W5w bulbs
« Reply #1 on: April 01, 2010, 09:12:10 am »
What do you mean? How to replace the sidelights?
Pull hard!
2006 E46 BMW M3 - 343hp
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: W5w bulbs
« Reply #2 on: April 01, 2010, 09:26:18 am »
They are a pain in the arse!
I will assume you have got to the stage of removing the rubber cap that hides the sidelight and indicator bulbs.
If you have the smallest hands in the world you can just give the plastic bulb holder a good tug (a twist might help) and it should come lose.
I have large hands, and so used a pair of needle nose pliers to pull the holder free, but be very careful not to pull on the wires. (if you have needle nose pliers with the bend half way down these would be even better.
On the drivers side there is less room to get to the rear of the cluster, but the black oblong box thats in the way can be removed with upwards pressure, as it just slots onto a mounting, which will make the job a whole lot easier.
HTH
Rich  :happy2:
Offline SteveS
Re: W5w bulbs
« Reply #3 on: April 01, 2010, 10:55:35 am »
i can get these out within seconds, granted you don't want big hands for this job tho.
just pull the rubber off and put ur fingers to the left corner if drivers side or right corner if passenger. just pull, a twist can help but its not locked in.
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline MR Pap
Re: W5w bulbs
« Reply #4 on: April 01, 2010, 08:26:20 pm »
Thanks for the replies lads, Ive got the indicator bulb out and was like WTF "this is nothng like the bulbs I have!" lol. Is the bulb I'm after behind the same rubber cap as the indicator bulb, just located to the left or right depending how you look at the car. Or am I fireing in the wrong direction lol  :happy2:
Offline v2brett
Re: W5w bulbs
« Reply #5 on: April 01, 2010, 08:57:50 pm »
your in the right place the bulbs point sidewards out towards the wing mate,   have a look with a mirror and it may help you work it out  :happy2:
Still Here!
Offline MR Pap
Re: W5w bulbs
« Reply #6 on: April 02, 2010, 12:44:50 am »
Quality, I'll av a look tomorrow.  :drinking:
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: W5w bulbs
« Reply #7 on: April 02, 2010, 04:29:38 pm »
Did you get it sorted?
Offline MR Pap
Re: W5w bulbs
« Reply #8 on: April 04, 2010, 07:25:48 pm »
Finaly got round to putting the bulbs in, here are the before and after.
  • MUBster DUBster
Re: W5w bulbs
« Reply #9 on: April 05, 2010, 11:25:39 pm »
That's one very clean car!!!  :happy2:  I feel like licking it!  :ashamed:
