Author Topic: deleting intercooler quick release clips  (Read 1043 times)
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« on: March 24, 2022, 11:01:19 am »
is there a way to get rid of the quick release connections like a different turbo pipe so you can just use a norman jubilee clamp?
Offline LC5F
  • -Receive: 80
Re: deleting intercooler quick release clips
« Reply #1 on: March 24, 2022, 12:48:49 pm »
Yes -
S3 or aftermarket intercooler.
Turbo outlet/discharge pipe.
Turbo silencer delete kit.
Suitable flexible boost pipes to work with above
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #2 on: March 24, 2022, 07:57:07 pm »
i have the s3 intercooler, which deletes one of those clips but still have the 1 on the turbo pipe,  so an s3 turbo disharge pipe doesnt use the clip?
Offline LC5F
  • -Receive: 80
« Reply #3 on: March 25, 2022, 10:28:02 am »
Cant say about S3 discharge - I found a discharge/pancake pipe for my K03 that had been fabricated to have a standard hose connector from this seller:
https://www.ebay.co.uk/itm/184786699592?hash=item2b06254548:g:jAwAAOSwcW9ggoej
I suspect the £450 price tag is just a placeholder to keep the listing alive.
That and aftermarket intercooler has deleted all the bayonet connections all mine apart from the turbo outlet.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #4 on: March 25, 2022, 05:50:13 pm »
have foud a forge silencer delete and aftermarket pipes, question is are we loosing any boost from the quick release clips?
im guessing if you can loose oil then you can loose air..
Offline Forcast
« Reply #5 on: April 01, 2022, 03:17:29 pm »
The ebay listing posted above if you message the seller he can modify them and get rid of the bayonet fitting. For both K03 and K04 Cars.
You will either have to send your pipe off to him or buy a new one and send it to him has he has none instock to modify.
There is also a few people on instagram that will do the same service.
Offline breeze
« Reply #6 on: April 02, 2022, 04:11:57 pm »
As an alternative, you could fit a new coupling to the hose you have.
On the intercooler output side, I replaced the coupling with one from Creations Motorsport (68/54mm). Beautifully machined and a really positive / tighter fitting seal to the intercooler. You may need a different size.
Tempted to do both ends of the hose on the input side.
« Last Edit: April 02, 2022, 04:30:40 pm by breeze »
