Author Topic: coding my new mfsw  (Read 1580 times)
Offline shepped
coding my new mfsw
« on: March 26, 2022, 10:12:48 pm »
Hi All
Apologies if this has been asked before
New to this forum and was looking for a bit of guidance on making my new MFSW work.
I have a 2006 golf mk5 and have purchased a multi function steering wheel for it (genuine
VW)
I have installed the wheel however none of the buttons work and i assumed that i just need to get it coded by someone with VCDS.
On further reading i think i might also need a steering column control unit but not sure.
The car has never had a MFSW on it and has midline clocks (not a highline display).
Any help an guidance on this much appreciated including who i can go to for coding via VCDS as i do not have this myself
Offline terrier
  • -Receive: 39
  • My Ride: GTI now gone
Re: coding my new mfsw
« Reply #1 on: March 27, 2022, 03:27:04 am »
https://www.uk-mkivs.net/threads/how-to-multifunction-steering-wheel-mk5-golf-h.10129/
 I think most use the 1K0-953-549-CH steering control module  I bought my module from HK for £50 Its still working  :happy2:
 If your lucky to get the search function to work on this forum there will be loads of info If not GOOGLE "retrofit" "install"
Offline shepped
« Reply #2 on: March 27, 2022, 10:28:19 am »
Thanks Terrier
Much appreciate reply just one question the part number you have given that part would suggest it has a steering wheel angle sensor?
I should have said my car is an 2006 R32 i am not sure but i believe it has an Electro Mechanical Steering Assist.
Any recomendations on who are a good company for coding as i did use one up in the Midlands for battery drain but have lost their number...I live in Surrey was a fair old drive from what i can remember
Offline shepped
« Reply #3 on: April 01, 2022, 11:14:14 am »
Hi
Thanks you all new controller is on its way but i need to get it programmed  with VCDS....any recommendations in the surrey area please. Unfortunately VW retro fit does not show up many local places
Thanks a lot
