Author Topic: Brake issues  (Read 1410 times)
Offline NorthWest
  • 2007 GTI
Brake issues
« on: April 07, 2022, 07:09:44 pm »
So replaced both side front pads and discs . Drivers side disc getting very hot . Replaced the caliper with brand new one as guessed that was the issue as torn booth on it .
-just after a spin with new caliper and bleed done and it’s still getting very hot compared to the passenger side ? I am completely lost now ?
Any ideas ? Maybe it’s just the new pads ?
Offline DBXdarkangel
  • -Given: 18
Re: Brake issues
« Reply #1 on: April 07, 2022, 07:42:32 pm »
Was it a genuine Branded caliper of some ebay jobby that was spray painted not powder coated?
Offline NorthWest
  • 2007 GTI
Re: Brake issues
« Reply #2 on: April 07, 2022, 07:52:56 pm »
No genuine caliper mate brand new
Offline FatWelshBoy
Re: Brake issues
« Reply #3 on: April 07, 2022, 08:36:13 pm »
Brake hose in good condition?
Offline NorthWest
  • 2007 GTI
Re: Brake issues
« Reply #4 on: April 07, 2022, 08:48:26 pm »
yep all looks good man. not sure what else to trouble shoot from here ?
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
Re: Brake issues
« Reply #5 on: April 07, 2022, 09:50:19 pm »
is it braking straight or does it pull to one side?
Offline G-olf
Re: Brake issues
« Reply #6 on: April 07, 2022, 10:20:14 pm »
Assuming everything with caliper is ok, wheel bearing??
Offline NorthWest
  • 2007 GTI
Re: Brake issues
« Reply #7 on: April 07, 2022, 11:03:30 pm »
No noise with wheel bearing anyways . I’ll pull caliper back off tomorrow and re check …all I can think of doing now is putting old pads back on (still loads of life) and see if the binding stops
Offline Flyingscotsman
Re: Brake issues
« Reply #8 on: April 08, 2022, 07:53:01 am »
It is likely to be the slider pins/bolts that are seized.  Try to clean and lubricate the old ones, or buy new ones.
Not reccomending particular aftermarket parts but just for illustration:
https://www.ebay.co.uk/itm/261942591008
Offline NorthWest
  • 2007 GTI
Re: Brake issues
« Reply #9 on: April 08, 2022, 08:20:37 am »
They are brand new and greased mate . Came with the new caliper
Re: Brake issues
« Reply #10 on: April 08, 2022, 08:42:40 am »
OK that's something eliminated.  Do they still bind with the old pads in?
Some of the VW pads come in different thickness (I think 12mm vs 15mm).  I found this out as the bigger ones wouldn't fit, however possible that they 'just' fit but bind.
Offline NorthWest
  • 2007 GTI
Re: Brake issues
« Reply #11 on: April 16, 2022, 03:46:56 pm »
so new brake line and still no good still getting hot
drivers side disc heating up to 40 degrees plus
passenger side staying at 18/20 degrees...
no fault codes on scan... what to do next? local mechanic looked at it couldn't find anything wrong?
Offline LC5F
  • -Receive: 80
Re: Brake issues
« Reply #12 on: April 17, 2022, 12:50:03 am »
Did you properly wire brush and clean the hub face before putting the new disc in place?
Could be rust pushing the disc out of alignment.
