Author Topic: cv joint?  (Read 1291 times)
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
cv joint?
« on: April 08, 2022, 07:19:38 pm »
drivers front wheel making a wuring sound when turning left only at slow speeds can i hear it,  bearing changed and still there,
thinking probably cv joint or drive shaft,
Offline LC5F
  • -Receive: 80
Re: cv joint?
« Reply #1 on: April 09, 2022, 01:40:06 pm »
I managed to hole my inner CV boot on mine, rather than fany around with grease etc. I just fitted a visually good used original entire drive shaft of ebay.
Offline JoshB
Re: cv joint?
« Reply #2 on: April 09, 2022, 10:16:09 pm »
CV joints tend to make more of a clicking sound than whirring to be honest, and on full lock in either direction. Could be the inner joint I suppose, gearboxes make whirring noises.
Getting too old for this...
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
Re: cv joint?
« Reply #3 on: April 09, 2022, 11:34:20 pm »
yeah i was always told clicking or knocking from cvs, but this is definately the drivers wheel only, it makes the sort of sound that you would get from a warped disc if it was dragging on the brake pad as the bent part passes over it, so its not a constant noise its something thats doing a circle and only making a noise at say the top of its turn if that makes sense, but its only on left turns when the weight is put on to the drivers side at slow speeds, i havent noticed any major vibrations when braking, so maybe driveshaft or a sticking caliper
