February 17, 2025, 10:57:24 am
All Things Mk5
How to Guides / Troubleshooting
One reason why fuel-rail pressure may be low....
Pages:
Topic: One reason why fuel-rail pressure may be low.... (Read 5288 times)
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: One reason why fuel-rail pressure may be low....
Reply #15 on:
May 19, 2022, 09:11:17 am »
56K is nothing, although it's not necessarily mileage/age related, but rather maintenance, or lack thereof that causes it.
adamvaughan
Taking part
-Given: 5
-Receive: 0
Reply #16 on:
May 19, 2022, 10:29:13 am »
I'll sleep peacefully for a while then.
ROH ECHT
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
Reply #17 on:
June 20, 2022, 04:48:44 pm »
I just got these pics from one I helped for having a persistent P0087 after replacing everything.
I posted the tri-lobe specs and he checked his and found he needed a new cam. When swapping the cam he posted these pics. It is obvious his replacement is slightly used, but measures well at 42.5 mm.
I wanted to share what just a bit over 1.5mm of wear looks like:
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
JettaJ
Newbie
-Given: 0
-Receive: 0
Reply #18 on:
October 08, 2024, 10:10:21 pm »
Sorry for resurrecting an old post but I have been chasing the P0087 code for a while now and pulled the HPFP and measured the lobes vs the base circle and am getting a lift of 4.6, 4.6 and 4.8 that is wore but not nearly what I have seen in other posts here. Does anyone know the wear tolerance? I have changed the bucket every 15k since I purchased the car (68k miles) and the original had very little wear. currently at 115k miles.
71 standard beetle 1800cc - currently in pieces
91 GTI 16v - cannibalized for Jetta and sold
97 Jetta GT converted to ABA 16v - sold
2007 - GTI current source of hair loss
Pages:
All Things Mk5
