Thought i’d post this here as well as some forums for as much information as possible. I have recently run into the issue of my 2007 vw gti being put into limp mode (no boost being pushed out, running n/a)
It is a 2007 gti with the fsi engine, stage 2 tuned with around 130k miles on it . Main maintenance has been kept up with heavily.
The issue first began after I did a pcv delete with the adapter for a catch can as well as set up a BOV that hooked up to the new pcv delete boost tap attached to the manifold.
The car ran perfect for around 4 hours until randomly the car went into limp mode and no immediate cels. After pulling over and turning off and on the car , the cel came on for codes p0243 (wastegate solenoid A) and p0444(EVAP system purge valve) .
After this issue came I decided to basically reverse everything I originally did , put the oem PCV back on and put the revision D DV back on instead of the BOV. The car is still in limp mode with both codes still popping up even after clearing . Any ideas or recommendations on what this could be or what to try?
