Author Topic: Drivers door problem  (Read 650 times)
Offline fazi123
« on: May 24, 2022, 11:06:34 pm »
Hi all,
I've got a problem with my drivers door. Everytime I lock/unlock the car it behaves as expected. However when I open the door, I don't hear the fuel pump prime & nor does the interior light come on. Sometimes I unlock it, get inside & begin to fiddle with my phone. The car will lock itself - as though the door has never been opened.
This only happens with the drivers door.
Any help would be appreciated.
Offline Sebas_theFish
Re: Drivers door problem
« Reply #1 on: May 27, 2022, 09:19:23 am »
Door lock actuator most likely, common problem.
Sent from my Samsung Smart Fridge
Offline FJB
« Reply #2 on: May 27, 2022, 05:59:09 pm »
The microswitch inside the lock module is faulty or the pcb has cracked solder joints. I have experienced both situations. I swapped the microswitch off of another broken module, which fixed it. On another occasion I found a cracked solder joint on the module just where the plug connector is soldered on, I just reheated the joint with a soldering iron and flux and it worked again.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
