Author Topic: Carbon Clean  (Read 1658 times)
Offline frasermk5
Carbon Clean
« on: May 31, 2022, 06:10:16 pm »
Been getting rough start up and misfire at idle, took it to a VW Indy and they have concluded that the intake valves are carbonned up and need cleaning. £457 for either sodium blast or walnut blast, sound about right in terms of price?
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=plhg5t5t58299bjtdaqep0lsct&/topic,131272.0.html
Re: Carbon Clean
« Reply #1 on: May 31, 2022, 06:24:10 pm »
I've seen a few places do it for 350 before but also seen it done for well over 500 just depends on who's doing it. Woukd say that's an OK price.
FYI Rtech have been doing a deal for a while now where they will do a carbon clean, injector cleaning and a tune for 650, bargain price really. Think AwesomeGTI are one of the ones I've heard doing just a carbon clean for 350 from memory? If either of those places are near-ish you that is.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=plhg5t5t58299bjtdaqep0lsct&/topic,19740.0.html
Re: Carbon Clean
« Reply #2 on: May 31, 2022, 06:36:45 pm »
Does that price include replacing all the injector seals?
Offline frasermk5
Re: Carbon Clean
« Reply #3 on: May 31, 2022, 07:00:15 pm »
Yeah so been quoted £457 for carbon clean, and replacement of seals (injector seals etc)
Re: Carbon Clean
« Reply #4 on: May 31, 2022, 08:59:09 pm »
Bit pricey I think. AKS are at £370  for the same job
Offline frasermk5
Re: Carbon Clean
« Reply #5 on: May 31, 2022, 09:13:03 pm »
Im in Norwich so bit far!
Re: Carbon Clean
« Reply #6 on: May 31, 2022, 11:24:45 pm »
I wasn't suggesting using them (although they are of course excellent), I was just giving you an example of pricing from a VW specialist.
Offline frasermk5
Re: Carbon Clean
« Reply #7 on: June 01, 2022, 07:59:49 am »
Thanks mate, fingers crossed this will solve my problems!
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
Re: Carbon Clean
« Reply #8 on: June 01, 2022, 08:59:45 am »
sounds a bit pricey, walnut blast at my local indi was £250,
Re: Carbon Clean
« Reply #9 on: June 01, 2022, 09:01:23 am »
I've never heard of gunked up intake valves causing misfires at idle.
Did they say "yes it's definitely that and cleaning them will sole the problem" because if they didn't say that then be prepared to still have the issue once they have been cleaned.
  • -Receive: 690
Re: Carbon Clean
« Reply #10 on: June 01, 2022, 09:11:10 am »
Too long and boring to go into detail, which no one reads anyway, but the cliff notes:
Cold starts and warm up uses a different injection mode. Severe intake restriction DOES cause misfires.
It's more common on the EA888 engine, but it can also happen on the EA113 if the build-up is bad enough.
Re: Carbon Clean
« Reply #11 on: June 01, 2022, 05:05:34 pm »
Interesting…. Honestly not something I have heard happen, although maybe most have the valves cleaned before this becomes an issue.
