So have removed the old cv joint, and am rebuilding the axle with the new one. Thrist washer and spacer fitted, but with the new circlip in the shaft groove, it seems impossible to get the new cv joint over it and onto the shaft. In trying it seems to be pushing the circlip off and seems to me it might break it and leave a bit of metal or two inside the joint causing a problem, which I won't be able to see. I can fit with without the circlip - is it okay to do this? I can't see what the circlip holds in particularly, especially once the driveshaft is reattached to the wheel.....
