January 10, 2025, 09:49:33 pm
All Things Mk5
Mk5 General Area
Changing front seats
Topic: Changing front seats (Read 1011 times)
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
June 18, 2022, 12:33:36 pm »
Just want to check before I knock my head off...
Disconnect battery and wait 30 mins.
Disconnect connection under seats.
Undo the 4 bolts. (what size are they and are they easy to undo or need a spray a while before?)
Cheers.
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Changing front seats
Reply #1 on:
June 18, 2022, 12:38:07 pm »
Sounds about right. Do GTI seats have airbags? If so, those yellow connectors can be a bit finnicky, so don't be too shocked if you get an airbag warning light afterwards
In my old MK4, I just sprayed a bit of contact cleaner on the plugs and reconnected to shift the fault.
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
Reply #2 on:
June 18, 2022, 02:01:34 pm »
Cheers pudding
terrier
Always Involved
-Given: 10
-Receive: 39
My Ride:
Reply #3 on:
June 18, 2022, 02:16:54 pm »
N90936901 M10 spline bolts Just replaced mine £12
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
Reply #4 on:
June 18, 2022, 02:40:56 pm »
Hoping they come out ok and can reuse.... Maybe I'll spray them before tackling.
terrier
Always Involved
-Given: 10
-Receive: 39
My Ride:
Reply #5 on:
June 18, 2022, 09:10:43 pm »
Quote from: Lewo on June 18, 2022, 02:40:56 pm
Make sure the spline bit is seated correctly before attempting to remove the bolt Or else is vice grips
ttelracs
Always Involved
-Given: 2
-Receive: 3
Reply #6 on:
June 18, 2022, 10:01:40 pm »
I took mine out to clean last year July, just used the correct spline on a half inch ratchet and they all came out no problem.
I didn't disconnect the battery though and had no issues, in hindsight I should have and would do next time.
JoshB
Always Involved
-Given: 4
-Receive: 7
Reply #7 on:
June 19, 2022, 09:35:17 am »
Do mk6 seats bolt straight in?
Getting too old for this...
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
Reply #8 on:
June 19, 2022, 02:33:26 pm »
All done cheers.
All Things Mk5
Mk5 General Area
