Author Topic: Door dropped after window regulator change  (Read 1817 times)
Offline Broomy
  • -Given: 18
« on: June 26, 2022, 08:04:21 pm »
As above I replaced the regulator in the d/s of the gti (3 door) and when it was all out back together the door has dropped considerably on the handle end. Saw the guide for adjusting the hinge but before I give that a go I just want to check that I shouldn’t disassemble the door skin to try and refit again before messing with the hinge.
TIA
  • -Receive: 690
Re: Door dropped after window regulator change
« Reply #1 on: June 27, 2022, 10:21:26 am »
Has the whole door dropped, or just the alignment of the outer panel?  You know when the whole door has dropped because it doesn't latch smoothly when closing it, and visibly lifts up as it hooks onto the B pillar.
Maybe the reduction in weight from removing the door skin and old regulator tweaked the hinge whilst you were fitting the new one?  I can't see there being enough slack in the door skin to allow so much misalignment?
Offline Broomy
  • -Given: 18
« Reply #2 on: June 27, 2022, 12:28:07 pm »
It’s the whole door, it’s catching on the sill protectors when I close it. The skin is def on straight. Just wanted to check I wasn’t missing something obvious as hinges are not my speciality lol. I think you’re right about the reduction in weight tweaking the hinge. Off to follow your guide on raising the door. Thanks 🙏🏼
  • -Receive: 690
« Reply #3 on: June 27, 2022, 04:29:51 pm »
Hopefully just that then  :happy2:
I still don't fully understand how that hinge works. Undo a nut and then open the door whilst lifting it at the same time. Odd. But if it works  :grin:
Question is though, why did the hinge adjust itself during your regulator swap if the nut wasn't loosened. Equally odd!
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
« Reply #4 on: June 27, 2022, 04:45:21 pm »
could it be the screws holding the skin in place iirc there are 3 different ones
Offline Broomy
  • -Given: 18
« Reply #5 on: June 29, 2022, 11:06:16 am »
Door now sorted using your guide. Thanks a million bud saved me a lot of hassle  :happy2:
  • -Receive: 690
« Reply #6 on: June 30, 2022, 12:29:52 pm »
Glad it helped  :happy2:
