Author Topic: Air con common leak areas?  (Read 1030 times)
Offline OldGTI
« on: July 16, 2022, 05:50:10 pm »
I have a 07 mk5 gti and it has a slow air con leak which takes about 10 days to run down. Any ideas of common places to look?
I don't mind taking it to a specialist as R-tech, VW main dealer and Maxtreme Ltd look after the car but I am too busy with work.
My friend has a garage and changed the condenser and put an aircon leak sealer in (I know guys I am an idiot but was desperate for a quick fix) but no joy.
Also does anyone know a aircon specialist in London or West Norfolk?
Thanks,
Al
Offline breeze
Re: Air con common leak areas?
« Reply #1 on: July 18, 2022, 02:01:47 pm »
If a dye was added have you tried looking for the leak with a torch? There aren’t that many hoses to trace.
« Reply #2 on: July 18, 2022, 03:07:57 pm »
Yep, ask your friend if he put UV dye in it.
Draining down in 10 days is quite a big leak and should be easy to spot with a UV torch.
Offline amanda
« Reply #3 on: July 18, 2022, 03:50:02 pm »
Mine was leaking from aircon rad welds had failed plus had a hose leak to. New rad and hose sorted the prob out was fine fil car was scrapped 😰😰😰😰😰😰😰
« Reply #4 on: July 18, 2022, 04:24:31 pm »
I wish someone would write mine off for me  :smiley:
