Author Topic: Xenon headlights dipped down  (Read 797 times)
Offline Numero9
« on: July 27, 2022, 10:02:25 am »
Went for an evening drive yesterday and noticed that the xenon headlights are dipped right down which gives quite poor visibility. I've read that it might be a broken level sensor but wanted to check if I am right in thinking there are 2, one on the front near side and one on the rear near side?
Could it be either one which is broken or is the front sensor the one which controls the headlights?
If this is intact is there anything else it could be?
Offline Sebas_theFish
Re: Xenon headlights dipped down
« Reply #1 on: July 27, 2022, 12:33:53 pm »
Yes there are two in those locations, on the front and rear control arms. Both control the headlight aim and if either one breaks it can aim the headlights into the ground like that. Check them both first because it's most likely that.
Sent from my Samsung Smart Fridge
Offline richtung
  • -Receive: 56
« Reply #2 on: July 28, 2022, 09:28:05 am »
I had this recently. It turned out to be the motor within the headlight unit itself (drivers side) that was faulty.
The motor was (off the top of my head) was £120 (genuine part) + a couple of hours labour.
Rich
Offline Numero9
« Reply #3 on: August 09, 2022, 09:17:17 am »
Does the golf only set the level once and that is it? The reason I ask is went for a drive yesterday evening, didn't put the headlights on till a little later into the drive and they remained low. Went to fill up and when I started the car again and put the lights on they levelled and were as they should be.
The car is part on a slight incline so wondering if this is why they remain low?
« Reply #4 on: August 09, 2022, 09:50:59 am »
They do a level check every time you start the car I believe.
Get a scan tool and look in the Xenon range module for fault codes.
