Author Topic: Thermostat questions  (Read 6864 times)
Offline Numero9
Re: Thermostat questions
« Reply #30 on: August 19, 2022, 03:23:57 pm »
Definitely seems that way, if I had small thin hands I suspect it would have been easier but it wasn't that difficult of a job.
Next few tasks are all cosmetic
Offline PorkPieBandit
« Reply #31 on: September 06, 2024, 02:32:06 pm »
New thermostat and sensor ordered. Are there any other o-rings or bits that I should replace along the way?
I had a coolant leak from the o-ring on the main thermostat (marked 5 on this diagram), the part number for it N90365302, might be worth replacing while you're in there :happy2:
Bit of an old thread revival but hoping someone whose done this job can help out - I'm replacing my thermostat this weekend and figured I should replace the o ring mentioned in the above comment. Ordered online and didn't think it would arrive in time, I tried to order from VW this morning and be reckons I've got the wrong part number? I didn't order with VW and my online order turned up so hoping it's correct. Can anyone confirm?
« Last Edit: September 06, 2024, 02:34:35 pm by PorkPieBandit »
Offline mjmallia
  • -Receive: 59
« Reply #32 on: September 06, 2024, 03:24:21 pm »
That o-ring should be replaced with the new thermostat......I would fit a genuine one, as it is a time consuming job.
I did mine a couple of months ago with gen parts, but also changed my 2005 plumbing to the later 2008 revise with no inline stats
Mike
South Coast
« Reply #33 on: September 06, 2024, 03:55:36 pm »
Sorry I wasn't super clear. I have a genuine thermostat but didn't get an o ring at the same time. I've now got an o ring (non genuine) but VW weren't sure I had the right part number. I think maybe it was a bit of a communication break down. When you did yours did you use the o ring with the part number N90365302? That's what I've ended up with so hoping it's correct!
« Reply #34 on: September 06, 2024, 04:56:39 pm »
Scrap all of this, just got home and checked the part that got delivered today, looks like I got confused ordering and ended up going for 06B-121-119-B  :doh: If anyone needs a spare main gasket for the thermostat let me know. I'll just risk it and not do the other O ring as it's not leaking and I've got the weekend booked out to change the thermostat.
