Author Topic: battery going flat  (Read 997 times)
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
battery going flat
« on: August 03, 2022, 09:15:11 am »
i bought a brand new yusa battery as my old one kept going flat, now this one does the same surely this cant be normal?
fully charged the battery will be completely flat in 2 days of not driving, thought batterys should last longer, my wee corolla hasnt been started in a week and it starts first time?
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=tdi1ner5dp4n1a9l0172g9c97j&/topic,131272.0.html
Re: battery going flat
« Reply #1 on: August 03, 2022, 09:26:56 am »
Somethings draining it most likely rather than the battery being at fault. Can't remember where to start to find out what exactly but tons of how-to's online about it being a fairly general and common fault some cars go through.
Offline mjmallia
  • -Receive: 54
« Reply #2 on: August 03, 2022, 09:51:18 am »
Have you changed the stereo recently?   Mk6 kit drains the battery in a mk5 without updated canbus
Have you plugged it into VCDS to see if any codes?
It could be a faulty canbus module not shutting down
Mike
South Coast
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #3 on: August 03, 2022, 01:00:28 pm »
i have a vag diagnostic tool but not vcds, has one of those rds300 upgraded stereo, but must plug in and see if anything comes up.
Offline titchy
« Reply #4 on: August 04, 2022, 08:44:32 am »
i had a prasitic drain turned out to be green corrosion across terminals below fuse box wire brushed some vaseline sorted
Offline OptionCream
  • Newbie
« Reply #5 on: August 05, 2022, 11:28:13 am »
Why was my post deleted?
« Reply #6 on: August 05, 2022, 03:39:46 pm »
For spamming old threads with irrelevant information.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #7 on: August 06, 2022, 08:39:14 am »
was down lifting the golfr from the indi after doing intercooler software and downpipe, i mentioned to him about the drain and he asked if it had an upgraded stereo i sad yes, he then replied i bet they didnt change the canbus data, but as im selling the car and its not insured i think i will just leave it for the next owner and knock a few pound off
