Author Topic: App that you can use to check timing  (Read 840 times)
Offline Freem82
« on: August 10, 2022, 07:08:32 pm »
As the title says really, is there an app available that I can use with my Bluetooth dongle that will allow me to look at the timing on the inlet cam ? I've got torque pro, but as far as I can see, you can't do that with it.
I cant afford to buy vcds at the moment.
Re: App that you can use to check timing
« Reply #1 on: August 11, 2022, 11:54:38 am »
You could try OBD11 which is the next best thing.
VAG don't put much information at all into the generic OBD data stream, which is all most apps can read.
Offline FJB
« Reply #2 on: August 11, 2022, 01:17:56 pm »
If you have an ELM27 Bluetooth device then I believe the Carly app will work with it. You can use OBDEleven, but you will need to buy the dongle, as it will not work with the ELM27.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline Freem82
« Reply #3 on: August 11, 2022, 03:32:14 pm »
Pretty sure I've got it sorted now in my icarsoft vaws handset. The only problem is, the reading never stays stable, seems jump around all the the time from 0 to -4 or thereabouts so I don't actually know what the true value is.
The chain isn't noisy, just want to know how much stretch is on it.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #4 on: August 11, 2022, 05:19:45 pm »
Pop out the cam position sensor and wipe off any swarf magnetized to it. See if it helps with the changing of position. If not, put out a request for someone near, you who has VCDS, to look at it for you. Hopefully you'll have something for yourself when you wish to check it again.
« Reply #5 on: August 12, 2022, 09:05:09 am »
0 to -4KW on the static timing channel is normal.
