Author Topic: Brembo discs warping?  (Read 2819 times)
Offline Lewo
« on: August 12, 2022, 12:44:05 am »
Got a bit of shaking going on when braking.
Has anyone had issues with Brembo discs warping at all?
upgraded the fronts to mk7r 340s, rears are standard.
What other make of discs are ok? Ate has been mentioned.
Just road use,  and not ragged much at all so if they have warped then that pretty poor....
Cheers.
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vhup6h3ltgen1vbgsp66onek0r&/topic,131272.0.html
Re: Brembo discs warping?
« Reply #1 on: August 12, 2022, 07:44:43 am »
New discs or 2nd hand with the 7r calipers? I've put my old brembo discs through he'll on my old std setup on Road and on multiple track days  and they were the only thing that didn't fail on that setup.  They are generally good quality.
« Reply #2 on: August 12, 2022, 09:02:42 am »
My Brembo rears warped pretty soon after fitment  :grin:  Rears ffs, they only do 30% of the braking and they still warped  :grin: :grin: :grin:
As we've discussed before, everyone thinks of giant Lambo/Ferrari brakes whenever the word Brembo comes up, but they sell cheap junk in the aftermarket like a lot of other brands.  Just for reference, my Brembos (and pads) were the standard spec ones from ECP and both are terrible.  Not using them again.
Lewo - go ATE or genuine VW.  And make sure the hub mating surface is sanded back completely flat before fitting a new disc onto them.
Offline GilesWoodward59
« Reply #3 on: August 12, 2022, 11:31:47 am »
I’ve been using EBC turbo groove discs for a while now and they have stood up well. I know EBC haven’t got a great reputation but I think in recent years their quality has improved significantly.
Edition 30 - No. 1233
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vhup6h3ltgen1vbgsp66onek0r&/topic,19740.0.html
« Reply #4 on: August 12, 2022, 12:39:49 pm »
Never had brembo HC discs warp. They seem well made to me. As pudding alludes to, not all brembo are made alike
Offline Lewo
« Reply #5 on: August 12, 2022, 01:47:20 pm »
All new calipers & discs.
Offline Lewo
« Reply #6 on: August 12, 2022, 01:49:20 pm »
Good shout about sanding back the hub. I uually put a smear of copaslip on those faces .
Offline Lewo
« Reply #7 on: August 12, 2022, 01:51:48 pm »
Offline Lewo
« Reply #8 on: August 12, 2022, 01:53:16 pm »
Not heard of Brembo HC, these are different from the standard Brembo?
« Reply #9 on: August 12, 2022, 02:18:45 pm »
Can’t remember exactly - got them from https://www.ebcbrakeshop.co.uk/ with a 15% discount they were offering at the time. Watch you get the right size - rears are 286mm (they also sell a 260mm which didn’t fit my Eddy).
« Reply #10 on: August 12, 2022, 03:14:04 pm »
High carbon variant.
« Reply #11 on: August 12, 2022, 03:24:10 pm »
Yeah get them clinically clean as its surprising how little dirt on the hub face can cause major disc run out.
Offline DBXdarkangel
  • -Given: 18
« Reply #12 on: August 12, 2022, 09:35:10 pm »
My brembo rear discs and pads are perfectly fine. Go with what you like and a trusted brand I say.
Forums will always have lovers and moaners of the same subject.
Offline LC5F
  • -Receive: 80
« Reply #13 on: August 12, 2022, 10:53:22 pm »
Copper grease is made up of copper filings - so not ideal between disc and hub.
ceramic grease or nothing would be better choices.
Mintex link talking about grease...not the  is the word is the word one:
https://mintex.com/copper-slip-vs-ceratec/?lang=en-gbr
Offline Lewo
« Reply #14 on: August 13, 2022, 03:29:33 am »
Ok cheers. Will clean and use ceramic if anything.
