Author Topic: 1.6 FSi 2007 Oil & Filter Change.  (Read 1133 times)
Offline slipd
« on: August 22, 2022, 10:25:02 am »
Hi guys,
I did a full oil/filter change at the weekend, completely drained it... I filled back up with 3.6l but upon checking the dipstick the next day it appears to be a bit high - the reading is just above the perforated mark on the stick.
I left the engine to drain for well over an hour after releasing the filter and there was barely a drip when I eventually put the sump plug in so I don't think there was any excess in the system? Now I'm starting to doubt the amount I refilled with? 3.6l is right for my engine isn't it?
Thanks.
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: 1.6 FSi 2007 Oil & Filter Change.
« Reply #1 on: August 22, 2022, 11:00:55 am »
3.6 according to Google.
Had you started it before checking the level ?
Offline slipd
« Reply #2 on: August 22, 2022, 11:05:15 am »
Thanks! I've checked when cold. 3.6l yeah - it's weird too, because if anything I'm stingy with my measurements so I would have expected it to be under...
Offline mjmallia
« Reply #3 on: August 23, 2022, 07:51:05 pm »
My wife has the 1.6fsi and it takes about 3.1ltrs when I do oil changes......always seem to have about a litre left from a 4ltre can.
I think 3.6ltrs must be a completely dry engine.
Mike
South Coast
Offline slipd
« Reply #4 on: August 23, 2022, 07:53:59 pm »
Thanks man! Yeah, I think I might pull out a couple months f hundred ml and get my line down... I don't think its the end of the world if I leave it but it did seem a bit high.
Offline LC5F
  • -Receive: 80
« Reply #5 on: September 03, 2022, 12:01:42 pm »
I have to admit I have gone over the max mark on many occasions, so I wouldn't be concerned.
There is at least 0.7ltr of oil that wont drain - this is split between the sump and the cam chain/vacuum pump. Edit - those are numbers for a 2.0, not a 1.6
If you still concerned if you can either get your hands on vacuum pump with a skinny hose you can suck a bit out of the dip stick tube or careful release from the oil drain.
« Last Edit: September 04, 2022, 01:08:21 pm by LC5F »
« Reply #6 on: September 03, 2022, 03:16:10 pm »
Yup. Every time I do an oil change I just chuck the entire 5 litre tub in. I can't be arsed to bugger about pouring exaclty 4.7 litres in. The excess will burn off eventually anyway  :grin:
Offline akbarirfan
  • -Given: 81
« Reply #7 on: September 07, 2022, 01:26:19 pm »
An extra 0.3L probably won't cause too much issue, but but unless you're dropping the sump etc, it's probably closer to an extra 0.6L.
I recently dropped the sump and I'm sure I put back in more than 4.6L to get to the mid-way mark on the dip stick.
Offline slipd
« Reply #8 on: September 07, 2022, 05:34:14 pm »
Thanks all!
I've just checked, this is a few weeks off of the change and the engine was cool. Last driven at lunchtime - it's now half five.
Not my actual dipstick, I didn't think to take a picture but the reading was:
Circled in blue. I think I'm goin go leave it :happy2:
