Author Topic: Swapped CAN Gateway - now sunroof doesn't work  (Read 1341 times)
Offline adamvaughan
« on: August 29, 2022, 09:13:25 pm »
Hello. In order to fit an RCD 330 I've swapped the CAN gateway in my Mk5 2.0 TSI estate (Jap import).
It all seemed fine but now I've realised the sunroof (full length glass sliding) doesn't work at all. I've compared a VCDS scan I've done afterwards with one I've done when I first got the car. It seems like the new CAN gateway can't reach control module 4F - Central electric II. Any idea why this might be (I made sure the installation list matched) and would this be the control module for the roof?
Both scans are below. I think all faults logged at 88269km are just those that popped up before I corrected the installation list for the CAN gateway. It seems a lot of hassle to just put a stereo in, am I better off using one of the CAN adapters for the stereo?
Any help is much appreciate
Code: [Select]
Saturday,21,May,2022,17:22:44:15724
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ8M308822   License Plate: WX57 WRL
Mileage: 86630km-53829mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 55 56 62 72
VIN: WVWZZZ1KZ8M308822   Mileage: 86630km-53829miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G524L0WG
   Coding: 040300431C070160
   Shop #: WSC 00066 000 00000
   VCID: 343112AB5238B96B1B7-8060
   VINID: 9E69EAAAA05BA8874300820208A5199A4C
2 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 86180 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:19:00
             Freeze Frame:
                    RPM: 852 /min
                    Load: 14.5 %
                    Speed: 0.0 km/h
                    Temperature: 84.0∞C
                    Temperature: 13.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 86350 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 52.0∞C
                    Temperature: 32.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AE
   Component: GSG DSG         081 1411
   Revision: 04508010    Serial number: 00000704230355
   Coding: 0000020
   VCID: 1C61DA0BDAA8112B337-8048
No fault code found.
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0037506
   VCID: 6889B6DB5E700D8B67F-803C
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79AFE39F35DA8403881-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000000653545
   Coding: E78F8F2700041500470000001C00000000097F075C000100000000000000
   VCID: 71BFDBBF6DAACC43301-8024
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 230607 020  0501
   Coding: 00038805
   Shop #: WSC 00066
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     110507 020  0105
   Coding: 00208933
   Shop #: WSC 00066
1 Fault Found:
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 48
                    Mileage: 86225 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.50 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AB    HW: 1K0 909 605 AB
   Component: 7F AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M027WWT
   Coding: 0014150
   VCID: 6C81CACB4A8821AB037-8038
   Subsystem 1 - Serial number: 6332MSME1C301B076
   Subsystem 2 - Serial number: 6342MSME145D3D7EW
   Subsystem 3 - Serial number: 6351HSME0D390A3FK
   Subsystem 4 - Serial number: 6361HSME0D4A687AQ
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012142
   VCID: 015F8B7F5D0ADCC3C01-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
1 Fault Found:
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
            008 - Implausible Signal - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 864 A    HW: 1K0 920 864 A
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0G524L0WG
   Coding: 0007403
   Shop #: WSC 09813 004 104857
   VCID: 2A0D0CD380FCFF9BB1B-807E
1 Fault Found:
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 86350 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:47:16
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway   H06 0052
   Revision:   H06 01    Serial number: 060507F2000838
   Coding: ED817F060002032003
   VCID: 323D14B3A82CB75B09B-8066
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 68
                    Mileage: 85954 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:03:29
01304 - Radio
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 65
                    Mileage: 86253 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:47:05
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            3HL 1212
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1134
   Revision: 31008001    Serial number: 00000031378502
   Coding: 0000694
   VCID: 3C213A8B7A68712BD37-8068
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 363528A34444AB7B253-8062
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 8090020052830C7F3F0484056008DF03E0FCA0
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695B8E358641BFB553-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB09  011 0160
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB09  011 0160
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1134
   Revision: 31008001    Serial number: 00000030578503
   Coding: 0000950
   VCID: 3D27378F61727823E49-8068
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 0 km
                    Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
             Freeze Frame:
                    Fault Status: 00111000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 86336 km
                    Time Indication: 0
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: 74B1D2AB12B8F96BDB7-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000001722158
   Coding: 0000144
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000001720266
   Coding: 0000144
   VCID: 3E2530836C74633BFD3-806A
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
             Freeze Frame:
                    Fault Status: 00100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 85927 km
                    Time Indication: 0
End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
Code: [Select]
Tuesday,16,August,2022,00:26:55:15724
www.Ross-Tech.com
VIN: WVWZZZ1KZ8M308822   License Plate: WX57WRL
Mileage: 88380km-54916mi   Repair Order:
VIN: WVWZZZ1KZ8M308822   Mileage: 88380km-54916miles
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 86180 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:19:00
             Freeze Frame:
                    RPM: 831 /min
                    Load: 22.7 %
                    Speed: 0.0 km/h
                    Temperature: 85.0∞C
                    Temperature: 39.0∞C
                    Voltage: 13.589 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
   Coding: 0000020
   Revision: 00H14001
   Coding: 0037506
   Coding: E78F8F270004151E470000001C00000000097F075C000100000000000000
   Shop #: WSC 00066 123 12345
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 00208933
   Shop #: WSC 00066
1 Fault Found:
00830 - Convertible Top Control Module (J256)
             Freeze Frame:
                    Fault Status: 01110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 88269 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
   Coding: 0014150
   Coding: 0012142
   Coding: 0007403
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4040K096018046
   Coding: ED817F06000203009101
   Shop #: WSC 01236 785 00200
   VCID: 6695B8E354641BFB553-8032
7 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 88269 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 55
                    Reset counter: 94
                    Mileage: 88269 km
                    Time Indication: 0
00463 - Control Module for Digital Sound Package (J525)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 88269 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 94
                    Mileage: 88269 km
                    Time Indication: 0
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 88269 km
                    Time Indication: 0
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 88269 km
                    Time Indication: 0
02874 - Control Module 2 for Central Convenience (J773)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 88269 km
                    Time Indication: 0
   Coding: 0000694
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 0 km
                    Time Indication: 0
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 52
                    Mileage: 88269 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
Cannot be reached
   Coding: 0000950
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 0 km
                    Time Indication: 0
   Coding: 0000003
Address 56: Radio
Cannot be reached
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:27, VBatt start/end: 12.3V/12.3V)-----------
