Author Topic: Top end clatter 2007 GTi.  (Read 1581 times)
Offline RussH
« on: September 03, 2022, 06:54:27 pm »
I know this is a pretty impossible ask but could anyone give me some ideas on this top end clatter?
I've searched this forum and tried everything I can think of.
Replaced fuel pump and cam follower.
New cambelt and tensioners.
Removed the cam cover and everything looked normal. No wear visible.
Listened with a stethoscope and pipe to try to pin the source down as best as I can. The noise seems to be coming from the centre rear, possibly slightly to the left (cam belt end). The heat shield above the turbo isn't moving/rattling but that's the area it seems to be coming from.
It's done 80k miles. Good condition, no running/performance issues.
The noise only starts when it's up to temperature.
It disappears as soon as it's slightly above idle, around 1050rpm.
I do have videos with it running minus the air box but I don't think I can upload a video?
Offline LC5F
  • -Receive: 80
Re: Top end clatter 2007 GTi.
« Reply #1 on: September 03, 2022, 07:22:39 pm »
Could be an exhaust leak at manifold - or even down pipe - they can make some strange noises, and this ties in with warming meatal expanding creating the leak/noise.
When you checked the valve chain and tensioner - you did check that the tensioner is keeping the chain taught?
If it was something in the valve train I suspect it would be constant - I can only think of stuck/gummed up hydraulic lifter, but thats a bit of a reach
Offline RussH
« Reply #2 on: September 03, 2022, 07:47:42 pm »
Thanks for the reply. I hadn't thought about an exhaust leak. I'll check that.
I haven't checked the cam chain. I wasn't sure if it was possible to just remove the cover to expose the chain?
To me it doesn't sound like a sticky hydraulic lifter. But who knows.
I should say it's been to two garages (one a VW specialist) neither could figure it out. The specialist suggested, as a process of elimination, testing the oil pressure. But apparently that's not an easy job.
Offline RussH
« Reply #3 on: September 04, 2022, 11:37:48 am »
Well I've made some progress!!
Using measuring block 93. When it's cold (no noise) the spec. is 28 degrees KW. Actual is rock solid at 27.5 to 28KW.
Once it warms up the actual starts to move between 24 and 28degrees KW. As it drops to 24-25KW this corresponds directly with the noise.
So. Could this be the oil seals in the variable cam timing module? As the oil thins (with temperature) this causes the instability/variation between 24 and 28?
Offline LC5F
  • -Receive: 80
« Reply #4 on: September 04, 2022, 01:04:45 pm »
Yes - the cover can be removed, but is a bit involved, requiring HPFP to be removed and a few of hidden bolts - and then it spills a good amount of oil out, so be ready with rags.
When you remove the cover it needs to be level to not damage the ceramic seals that control the VVT phaser.
For best visual and physical access I recommend both battery and battery tray out.
Offline RussH
« Reply #5 on: September 04, 2022, 06:00:07 pm »
I think that's my next plan, open the variable cam timing cover. The VCDS interrogation shows that the chain is in good condition but I'll check/replace the oil seals in the module.
Plus do some research into how it actually works to try and figure out why it's unstable.
Offline RussH
« Reply #6 on: September 06, 2022, 09:46:49 pm »
I could be close to fixing it:)
I took the cam adjuster solenoid out and cleaned it. It looked perfectly clean but it's now virtually fixed. 99% fixed!
It's made the noise once for maybe 1 or 2 seconds since I removed and cleaned the solenoid.
So even if it returns I'm confident that I've found the problem.
« Reply #7 on: September 07, 2022, 08:31:13 am »
A few of us have had this rattle and it was caused by a broken oil control ring in the chain cover.  The middle one in my case.
Offline RussH
« Reply #8 on: September 07, 2022, 11:22:53 am »
My next step was getting into the valve timing module to replace the oil seals. I tried to order them from VW (wanting to avoid the knock offs made out of recycled egg cartons) but they couldn't find them. Mine is an Edition 30 as well so that maybe a problem in the VW parts system.
But I'm pretty confident I've fixed it. Happy days!
The not knowing what the problem was was driving me nuts.
« Reply #9 on: September 08, 2022, 12:23:25 pm »
For future reference - https://www.akstuning.co.uk/shop/home/345-genuine-camshaft-adjuster-housing-seal-set.html
Edition 30 and GTI share the same parts, so shouldn't cause the dealers any problems regarding their parts system.  I've never struggled getting anything for mine.
The VVT solenoids aren't known to directly cause a rattling noise, so consider it a temporary fix until it's stayed quiet for at least a month of high and low speed driving.
Offline LC5F
  • -Receive: 80
« Reply #10 on: September 10, 2022, 04:42:04 pm »
I have been running knock off ones for a year - lets just say breaking a £7 a seal installing it is a lot more palatable to breaking one at £14 a pop.
If you do replace the seals reload them outside first - as it fills in the groove and the next seal will ride over to the next groove.
