November 24, 2024, 04:10:26 am
All Things Mk5
How to Guides / Troubleshooting
Oil pressure stop ???
Topic: Oil pressure stop ??? (Read 1224 times)
Rondon77
Newbie
-Given: 0
-Receive: 0
September 10, 2022, 08:34:33 pm »
My gti is coming up oil pressure stop engine on clocks so I’ve done a oil and filter change on it and still sane any one know what the problem is and how to sort it ??? Thanks
Clarkj93
Won't Shut up.
-Given: 7
-Receive: 34
My Ride:
Re: Oil pressure stop ???
Reply #1 on:
September 11, 2022, 08:28:33 pm »
Sounds like it could be a blocked oil pickup pipe. Quite well documented issue on these engines. They can be cleaned out and the sump re-sealed to sort usually.
Budget track build:
https://www.mk5golfgti.co.uk/forum/index.php/topic,131272.0.html
LC5F
Just look at my post count
-Given: 16
-Receive: 80
Reply #2 on:
September 11, 2022, 09:47:36 pm »
Yes - blocked oil pick up is common, first place to look
mjmallia
Won't Shut up.
-Given: 3
-Receive: 54
Reply #3 on:
September 12, 2022, 08:17:35 am »
That and also cracked/broken seal rings on the cam actuator as I had both
Mike
South Coast
S3 8L ---- Golf Mk4 GT TDI ---- Lupo GTI ---- A4 B6 Sline ----
Golf Mk5 GTI
Rondon77
Newbie
-Given: 0
-Receive: 0
Reply #4 on:
September 12, 2022, 09:53:35 pm »
Thanks been told oil pick up so will drop sump and have a look how do I find out if pump is ok thanks really appreciate your help
blingsta
Always Involved
-Given: 2
-Receive: 2
Reply #5 on:
September 20, 2022, 08:30:01 am »
did you check your oil pick up pipe? was it clogged?
All Things Mk5
