Author Topic: Crazy quote for brake dust sheilds?  (Read 2480 times)
Online shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« on: September 13, 2022, 08:25:33 pm »
I was just quoted £430 to replace both rear brake dust shields.  Quoted 4 hours labour.  I'm thinking it's way off the mark.
I was expecting it to be around £100 -£120
It's a local garage who up until now have seemed to offer good value.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ans9g1k73a9ngi34gj4v2bfu9j&/topic,19740.0.html
Re: Crazy quote for brake dust sheilds?
« Reply #1 on: September 13, 2022, 08:51:13 pm »
Fairly big job as not only the brakes have to come off but also the hubs have to come off too.
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ans9g1k73a9ngi34gj4v2bfu9j&/topic,131272.0.html
« Reply #2 on: September 13, 2022, 09:40:38 pm »
If they're rusted and rattling sometimes you can just about cut them off with tin snips. That's what happened to mine anyway. If you can get away with that I wouldn't bother replacing them unless you're going off roading, I don't run any with zero issues even in bad uk weather.
I didnt think the hubs had to come off but I have not had do much more than the rear shocks and pads on the rear so happy to be proven wrong.
Online shail
« Reply #3 on: September 13, 2022, 09:58:20 pm »
They are rusted and one is rattling.  I'm going to have a look at the weekend to see if I can cut them out and not replace if I can do it without taking hub off..  Spending that much money on them just isn't on top of my list!
I am having flashbacks to the total ball ache removing the caliper carrier is. I swore blondnid never attempt that ever again!
Offline Clarkj93
« Reply #4 on: September 13, 2022, 10:17:18 pm »
Yeah at a price that steep you may aswell do the discs at the same time since the caliper carriers are a bitch to get off anyway to replace them.
Online shail
« Reply #5 on: September 13, 2022, 10:31:58 pm »
I did the rear pads and discs about 25k ago, so they are still in good shape (unfortunately!!)
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
« Reply #6 on: September 14, 2022, 06:48:46 am »
The rears can be cut to fit NO need for all that work  I have RIDEX ones fitted  ebay search for FEBI ones You will need 3 new fixing bolts too
« Last Edit: September 14, 2022, 06:54:51 am by terrier »
« Reply #7 on: September 14, 2022, 08:26:43 am »
Wait until you need a rear bearing, or a brake job.  Some people cut out the thin section of the new shield across the 2 lower bolts, which will negate the need to remove the hub, but it may make it floppy like a slice of Tesco basics ham.
It's not that big a job anyhoo. Removing the bearing hub is a piece of soft and squishy cake. It's one bolt  :grin:  The only biatch bit is the caliper carrier bolts, but even that is just a matter of having the right tools and experience.
Online shail
« Reply #8 on: September 14, 2022, 09:12:23 am »
I've now ordered some off eBay and some new bolts. Going for the cutting method for now and leaving the hub where it is.
Offline terrier
  • -Receive: 38
« Reply #9 on: September 14, 2022, 02:12:53 pm »
Paint any bare metal to combat rust (Im sure you have enough rust to tackle) :grin:
Offline mjmallia
  • -Receive: 54
« Reply #10 on: September 14, 2022, 02:36:37 pm »
I cut the thin section out the middle of the shield, to then slot it over and bolt down..........similar to what the fronts are like.  No issue at all
Mike
South Coast
Offline LC5F
  • -Receive: 80
« Reply #11 on: September 15, 2022, 10:15:44 pm »
Very likely the shield will just pull off or twist off
If your doing it properly, getting the brake carriers off that's the hardest part. the rest is straight forward
If you like stone guards there are Galvanised ones out there - IIRC the bolts holding them on are M5 - use stainless bolts.
Online shail
« Reply #12 on: September 16, 2022, 02:52:46 am »
I am hoping they just pull off.  I have bought new shields and bolts, although I've got M6.  I'll attempt the to take carrier off.  Last time I ended up buying a swivel head ratchet which helped with access and leverage.
Offline probedb
« Reply #13 on: September 16, 2022, 02:56:11 pm »
Jayzuz! It cost me £50 for one side with me supplying the shield and bolts.
« Reply #14 on: September 16, 2022, 05:33:09 pm »
Aye, silly price isn't. Similar to the chap on here getting quoted £420 to fit a carbon can. A mate told me the other day he was quoted £450 to fit springs to his M135i, and it's just as easy to do as a MK5. It seems local garages are getting a tad greedy.
But yeah, I paid about £35 each for the shields from the dealer.
