Author Topic: I think my ECU has died  (Read 10465 times)
Offline MrFernze
« on: September 14, 2022, 06:51:53 pm »
Hello everyone!
I have been driving my car for a short time after rebuilding it and getting it back on the road, Tuesday my car just decided not to work. I believe that the ECU has died as I can still communicate with my DSG box which has flagged some codes but I believe that's relative to the ECU not being able to communicate with it.
The car itself will not start and I have checked all other areas, air/fuel/combustion etc. My first thought was to connect my OBD2 reader but it will not auto read the vin or show any codes related to the engine.
I was just wondering if I purchased a 2nd hand ECU, are they directly plug and play or would I need it coding?
TIA for any replys!
Re: I think my ECU has died
« Reply #1 on: September 15, 2022, 08:49:52 am »
Check powers, grounds, fuses & relays first.  If you can't hear the throttle body whining/clunking when you turn the ignition on, the ECU either has no power, or it's dead as you suspect.  I've never heard of these ECUs simply dying, so it could be a simple power feed issue.
If you get a second hand ECU, the immobiliser will need removing.  There's an ebay seller who sells de-immobilised ECUs ready to go, but he's expensive.  Another option is to send your ECU off, along with the spare one, to get it copied over and posted back.
Offline MrFernze
« Reply #2 on: September 15, 2022, 09:41:24 pm »
Hey Pudding, cheers for the reply as always!
Yeah I've checked the fuse box and the positive connectors with a circuit tester and all fuses work perfectly, I did quickly clean them with a electrical fluid cleaner and then dusted them off with a wire brush and retested them. All worked fine and plugged the ecu back in, tested and the car continued to crank but shortly die afterwards. I checked to see if the ECU could be read with an OBD2 reader but came across the same issue. I'm going to get an multimeter tomorrow and test the ohms and power to the ECU, to find out if there are any discrepancies.
Regards,
MrFernze
« Reply #3 on: September 16, 2022, 09:47:12 am »
No worries.
It might be worth getting a pin out diagram for the ECU and check it has power and ground at the ECU plug(s)....and also check the CAN lo and CAN hi pins for activity with the meter, which would indicate the CAN gateway is at least trying to talk to it.  That at least will verify the wiring is fine end-to-end.
If the ECU does need replacing, you may have already noticed it's held into it's bracket with shear bolts, which will need drilling out before you can hoik the ECU out, which is annoying!
« Reply #4 on: September 16, 2022, 10:04:21 am »
Check relay 100 in the engine bay as well, that's the ECU's.
So does the engine actually fire up?  Cranking isn't controlled by the engine ECU.
Offline MrFernze
« Reply #5 on: September 20, 2022, 09:57:21 pm »
Hey pudding, the car cranks and starts up but shortly dies. I believe it's a issue with either the ignition switch or a relay from testing literally all the standard fuse's with a circuit tester, removing them and testing them all individually with a fuse tester. All being fine and tested all the positive connectors to the fuse box, which all resulted in passes by my book. My only concern was the relay's so I'm going to get a new one tomorrow and change the ignition switch. I forgot to mention that I tested the codes previously and had a bunch. Some are minor and slowly sorting them out as I have only just got the car running but didn't expect the car to die so suddenly  :surprised:
00944 - heated exterior mirror passenger side
00821 - antenna 2 for radio R93 open circuit
01334 - door control module rear right no signal/communication
01135 - interior monitoring sensors no signal
01134 - Alarm horn no signal
00931 - locking module for central locking rear rigght
00930 - locking module for central locking rear left
01314 - engine control module no signal
01333 - ecu left rear door no signal
00883 - ignition switch D electrical problem in circuit intermittent
01305 - databus for infotainment no signal
01320 - climatronic ecu no sigal
05634 - power supply voltage 30 p1602 lower limit reached
05635 - inter control module failed self
However, thank you for the relay number as I've been trying to search for that information but have been coming up short for some time!  :happy2:
« Last Edit: September 20, 2022, 09:59:22 pm by MrFernze »
Offline ttelracs
« Reply #6 on: September 21, 2022, 08:57:55 am »
Immbiliser?
I had this issue when I thought I had a bad ECU but only when I plugged in a supposed unlocked one.
Immobiliser key didn't show on the dashboard but the ECU guy I had confirmed it was the immobiliser which allows it to crank, fire, run for about a couple of seconds then immediately die.
Offline MrFernze
« Reply #7 on: September 22, 2022, 11:01:35 pm »
Immbiliser?
Its either that or the ECU, but my thoughts are still going to ECU because I can't scan my OBD2. My friend gave me a card for a key guy, so ill call him next week.
« Reply #8 on: September 26, 2022, 10:17:47 am »
That is indeed a classic sign of immobilisation, it starts, then cuts out immediately.  The fact it actually starts and runs, we can probably outrule the ECU as being faulty.
With that many fault codes, I'm leaning towards a bad CAN Gateway or a bad earth, broken wires etc.  The gateway lives above the pedals, directly underneath an access hatch under the wiper motor.  If the seal on said hatch leaks water onto the CAN gateway, well, you get a shed load of fault codes and communication failures.  But the same can also happen with bad grounds and broken wires. The wires in the harnesses that pass through the doors and hatch are old favourites for that!
Offline MrFernze
« Reply #9 on: October 07, 2022, 09:33:42 pm »
I'll have a look into it, I've ordered VCDS to get a clearer picture from V Tech UK but they are taking their sweet sweet time.
Regards,
Ryan
Offline MrFernze
« Reply #10 on: October 11, 2022, 08:39:05 pm »
These are my logs below, I had a gent come and visit the car as my VCDS still hasn't been shipped but I will be getting one soon  :happy2: We checked the CAN gateway with his own and some clocks but those were not the issue. So from his thoughts, it may be that the CAN high/low wiring must have a been cut or faulty in general. But its still all in the air. He did mention it may be something with the powertrain data bus as the connection will not communicate to everything else.
Offline MrFernze
« Reply #11 on: October 11, 2022, 08:44:48 pm »
Code: [Select]
Tuesday,11,October,2022,18:33:34:24764
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W022316   License Plate: GX55 OXD
Mileage: 224920km-139758mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W022316   Mileage: 224920km-139758miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001950675
   Coding: E58D0F2700041800001400001400000000087F075C
   Shop #: WSC 01279 785 00200
   VCID: 2B02FC4B0F033B930A1-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
10 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 70
                    Mileage: 224543 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00984 - Left Tail Light (M4)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 75
                    Mileage: 224543 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 75
                    Mileage: 224543 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 224927 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 6.80 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 224927 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.20 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.80 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.80 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.15 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 13.20 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.15 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012112
   VCID: 77AA103B83CB4F73BE9-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
4 Faults Found:
00002 - Transmission Control Unit
00446 - Function Limitation due to Under-Voltage
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00011 067 57207
   VCID: 6E84355FFC910EBB6DF-803A
6 Faults Found:
00381 - Databus Instrument Cluster
01309 - Power Steering Control Module (J500)
01315 - Transmission Control Module
01316 - ABS Control Module
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056200B15
   Coding: 3F3F0340070003
   VCID: 2A0CF94F00F9229BF17-807E
13 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:49
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 81
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:49
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 81
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:49
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 178
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:26:35
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 35
                    Mileage: 224417 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:33
01312 - Powertrain Data Bus
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 35
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:02:48
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 1
                    Fault Frequency: 8
                    Reset counter: 75
                    Mileage: 224522 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:04:06
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
   Shop #: WSC 00000 000 00000
No fault code found.
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0972
   Coding: 0000692
   VCID: 3828D307CE55800B773-806C
3 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00913 - Window Regulator Switch; Front Right Driver (E81)
            008 - Implausible Signal - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01C802087F2D8405485FC69010CC
   Shop #: WSC 00000 785 00200
   VCID: 79AE1603B5DF5903C8D-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
13 Faults Found:
00830 - Convertible Top Control Module (J256)
01517 - Control Module for Trailer/Towing Sensor (J345)
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
00668 - Supply Voltage Terminal 30
00931 - Locking Module for Central Locking; Rear Right (F223)
00930 - Locking Module for Central Locking; Rear Left (F222)
01038 - Central Locking Thermal Protection
            000 - - - Intermittent
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 392ED603F55F990388D-806C
3 Faults Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End----------(Elapsed Time: 00:44, VBatt start/end: 12.1V/12.1V)-----------
« Reply #12 on: October 12, 2022, 03:33:12 pm »
"19 - CAN Gateway - Malfunction 0010"
That is the standout one for me.  Without Colonel Gateway in charge, none of the troops will be able to communicate with each other.
At least the immobiliser is happy, not that you could drive the car away anyway  :grin:
Given the vast amount of communication related faults, it's got to be Colonel gateway. I believe the comms from OBD2 port start with him and spread out from there.  A severed CAN Line would normally show up as a no comms on the module the wire break is nearest.
Offline MrFernze
« Reply #13 on: January 06, 2023, 01:18:58 pm »
I finally had the time to look at my car and check a couple things, firstly I didnt want to go through the mess of trying to find the issue through CAN wiring, I put a post up on TFSI owners Club FB and someone PM'D me. Showing all the details he reccomended me to purchase a BCM. Purchased it from Danny and fit it, cleared the codes and the car fired up   :pomppomp:
Hopefully if anyone has the same issue, try purchasing a 2nd hand BCM and installing it!
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #14 on: January 06, 2023, 07:38:22 pm »
Thanks for posting a fix .
