Author Topic: I think my ECU has died  (Read 8768 times)
Offline MrFernze
Re: I think my ECU has died
« Reply #15 on: January 07, 2023, 09:43:41 pm »
Thanks for posting a fix .
No worries, hopefully someone who has the same issue doesn't have to wait months on fixing it. Sometimes you just have to be the unlucky one but at least it's back on the road   :happy2:
Offline MrFernze
« Reply #16 on: January 08, 2023, 02:26:48 pm »
Just an update, was going to my dads and on the way my car broke down. :laugh: BCM died again from my assumption, so it must be something else that is killing it. I tried my ODB2 once again after the car died but had no luck with communicating with any of the modules. Similarly to what happened previous to the fix.  I'll keep this thread updated for a fix once I get it sorted, but I'll be taking it to a garage to check some electronics. Firstly I'll purchase a new one from TPS and go from there. Hope I'll get it sorted before the summer. It's all fun and games!!!
Regards, MrFernze
Offline MrFernze
« Reply #17 on: February 26, 2023, 11:47:49 am »
eature=share
I did find this yesterday as I needed to check the wiring due to previously starting the car and the fan started going to the moon. Shortly disconnecting the battery. Tried moving the ECU around for some odd reason and the car started, so continued looking into the wiring and found that some of the wires were broken which was in the video. So I've downloaded the circuit diagrams, and I'm going to try to find the issue at hand. Also to note, disconnected the ABS module due to many people telling me to test it over 3 other forums but no help and I scanned and cleared codes each time.
Offline MrFernze
« Reply #18 on: March 05, 2023, 08:22:24 pm »
So I believe that the J500 is faulty, does anyone have any more information regarding the continuation of a fix. Disconnected the power steering wire seen in the video, I believe its that is the reason for the powertrain having communication issues due to this. I still had the ABS module unplugged but I will plug this in tomorrow and rescan it. It starts every time now, but I want to be 100% before I drive it anywhere.
Code: [Select]
Sunday,05,March,2023,19:15:49:02823
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W022316   License Plate: GK55OXD
Mileage: 224950km-139777mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W022316   Mileage: 224950km-139777miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2321880
   Coding: 040300031C070060
   Shop #: WSC 01279 785 00200
   VCID: 2411E0CC72DB4F5A4BB-8070
   VINID: 9E69EAAAA05BA869C00820C11898CAA7C1
6 Faults Found:
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 224927 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:40:56
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.954 V
005635 - Internal Control Module
               P1603 - 004 - Failed Self-Test - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.827 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
008214 - Intake Manifold Flap Position Sensor (Bank 1)
               P2016 - 002 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 35.0°C
                    Voltage: 12.954 V
Readiness: 0110 0100
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000601111214
   Coding: 0000020
   VCID: 1471B00CA27B3FDABBB-8040
1 Fault Found:
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 224957 km
                    Time Indication: 0
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001950675
   Coding: E58D0F2700041800001400001400000000087F075C
   VCID: 2B030BF01F0580228A1-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
7 Faults Found:
00984 - Left Tail Light (M4)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01111100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0G7CH4
   Coding: 0012870
   VCID: 372B2780D34D34C2FE9-8062
   Subsystem 1 - Serial number: 6332MSME0F3C7A41N
   Subsystem 2 - Serial number: 6342MSME12106670
   Subsystem 3 - Serial number: 6351HSME075C47709
   Subsystem 4 - Serial number: 6361HSME075E4C0FP
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012112
   VCID: 77ABE78093CDF4C23E9-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
No fault code found.
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056200B15
   Coding: 3F3F0340070003
   VCID: 2A0D0EF410FF992A717-807E
5 Faults Found:
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:09
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:09
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:09
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:10
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:10
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Part No: 1K6 920 962
   Component: IMMO            VDD 1012
   Shop #: WSC 00000 000 00000
   VCID: 6E85C2E4EC97B50AEDF-803A
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0972
   Coding: 0000692
   VCID: 382924BCDE533BBAF73-806C
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01C802087F2D8405485FC69010CC
   Shop #: WSC 00000 785 00200
   VCID: 79AFE1B8A5D9E2B248D-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
6 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
01312 - Powertrain Data Bus
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 392F21B8E55922B208D-806C
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4102409
   Coding: 01000400020001
   Shop #: WSC 31414 790 31414
   VCID: 33331390CB35D8E2C21-8066
2 Faults Found:
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:31
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:51:27
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End----------(Elapsed Time: 00:51, VBatt start/end: 12.9V/12.9V)-----------
Offline MrFernze
« Reply #19 on: April 03, 2023, 08:20:00 pm »
Hey guys, so it's been fixed with some issues with codes and basic settings but its my last year at university and I've been concentrating on that. Yesterday me and a friend, my friend mostly installed a gen3 power steering rack after diagnosing that the CAN HI/LOW read that the resistance was totally f*cked https://youtu.be/tyKK2JZ4U68. Once it was installed, the car started easily without issue. I just need to do the basic settings and work through some codes. Hopefully I'll be able to drive it soon. It's been way too long.
Code: [Select]
Monday,03,April,2023,14:49:28:02823
www.Ross-Tech.com
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 224927 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:40:56
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 71.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.462 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 72.0°C
                    Temperature: 18.0°C
                    Voltage: 13.335 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 0.000 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 72.0°C
                    Temperature: 18.0°C
                    Voltage: 13.462 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 71.0°C
                    Temperature: 18.0°C
                    Voltage: 13.462 V
   Coding: 0000020
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40D94C5C8683737A4F3-8014
6 Faults Found:
00778 - Steering Angle Sensor (G85)
            000 - -
01435 - Brake Pressure Sensor 1 (G201)
            005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
01314 - Engine Control Module
            008 - Implausible Signal
Cannot be reached
   Coding: 00065493
   Shop #: WSC 01279
   Coding: 00207646
   Shop #: WSC 01279
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0012870
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - MIL ON
   Coding: 0012112
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00011 067 57207
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Subsystem 1 - Part No: 1K0 907 530 F
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Coding: 0000692
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 234    2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F3B1FE02B1DFC02A69-807A
1 Fault Found:
            008 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:05:17
             Freeze Frame:
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 13.0°C
                    Count: 4
                    Steering Angle: 11.16°
                    Count: 0
                        SteerAng Init
   Component:    KSG              0401
5 Faults Found:
   Coding: 0000692
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 224957 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:05:36
Cannot be reached
Cannot be reached
End----------(Elapsed Time: 01:08, VBatt start/end: 12.2V/12.2V)-----------
Offline MrFernze
« Reply #20 on: April 03, 2023, 08:22:55 pm »
After removing the rack, we wanted to see the damage. If anyone has had any weird symptoms. Make sure to get it checked out before driving it anymore. Thankfully the power cable insulation held up and didn't catch fire.
Offline mjmallia
« Reply #21 on: April 04, 2023, 09:45:54 am »
 :confused:
Well done on sorting it all.
Mike
South Coast
« Reply #22 on: April 05, 2023, 01:45:48 pm »
I guess that's why the Gen 3 racks have an upgraded harness!  Good work  :happy2:
Offline MrFernze
« Reply #23 on: April 27, 2023, 12:36:02 pm »
Thanks for the previous help pudding. Currently getting a lot of voltage 30 codes but slowly getting there :P
« Reply #24 on: May 05, 2023, 08:22:26 pm »
Ah yeah, 30 is the Battery + post I believe? There are a few modules that are 'hot' at all times, so that error code is quite common.
You have the patience of a saint and well done for keeping us informed.  So many forums have dead threads with no answers, so top man  :happy2:
I find vehicle wiring incredibly tedious and unrewarding to troubleshoot. I think I would have thrown the towel in an scrapped the car, but Kudos to you for tackling each issue systematically  :smiley:
How is the engine bay fuse board looking?  With some fried steering harness wiring like that, I wouldn't be surprised if the fuse box could be slightly toasted as well.
Offline MrFernze
« Reply #25 on: May 10, 2023, 12:46:41 pm »
Honestly Pudding, if I didn't have so much f*cking money into it I would have scrapped it. To be honest I should have when it first died but I'm way in too deep that the mrs would be hella angry if it didn't work (still doesn't lmfao). I could have tore it apart months ago but I wanted the rabbit to be taken care of and its my first project car. Now I'm getting a Signal to fuel pump issue and I'm honestly just tired.
« Reply #26 on: May 12, 2023, 06:45:24 pm »
Yeah I know the feeling. I don't keep costing spreadsheets like some folk do as it's too depressing. I reckon with the money I've spent on fixing and modifying VWs, plus all the 20mpg fuel costs over the past 20 years, I could have driven a diesel sh1tter or 5 for that long, saved the money and bought a 911  :grin:  But car enthusiasts always seem to prefer the school of hard knocks  :grin:
Thinking back to the beginning where you said these problems began after you rebuilt it, was it fine before hand? Did the engine come out? Just wondering if a wire got accidentally got pinched and shorted out, which caused all this grief?  If any of the CAN modules get shorted out, that can upset the rest of them, including the gateway.
Having said that, the steering rack wiring harness on Gen1 racks was a known weakness. VW under spec'd the wire size, which in some cars caused the crispy mess you ended up with. If one of those shorted out thin wires is a CAN signal, I can see that causing you some problems. Before I switched to a Gen 3 rack and harness, I did notice with hefty steering inputs, it felt like the rack couldn't keep up and got mega stiff all of a sudden. I suspect that was the motor struggling for current over the thin wires.
Anyway, keep soldiering on, you'll get there. I'll have a look at your LPFP thread.
Offline MrFernze
« Reply #27 on: January 15, 2024, 08:30:57 am »
I figured out the fuel issue was due to installing the ecu incorrectly whilst I was trying to upgrade the ecu holder as the original is ass. A pin was bent and the car started fine shortly after the fix. Honestly, I'm not sure what fck'd the steering module, the engine was upgraded as you know but I'm sure I did it as carefully as I could when working on it alone.
« Reply #28 on: February 10, 2024, 01:00:38 pm »
I think you were just unlucky with that. The Gen1/2 rack was known to have under specced wiring. Thank god it didn't torch the car!
