Author Topic: Disc issue . Pads not using full disc surface  (Read 929 times)
Offline NorthWest
  • 2007 GTI
« on: September 20, 2022, 08:59:57 pm »
Can’t seem to resolve this issue . Brand new caliper …new break line …new bads & disc …this one side (drivers front) is having an issue where the pad is not using the full disc ? Any ideas on what I can try next ? Passenger side is perfect
Offline blingsta
Re: Disc issue . Pads not using full disc surface
« Reply #1 on: September 21, 2022, 10:21:22 am »
isnt the shape of the pad generally higher and then smooths out over time to see more pad surface?    but it doesnt explain why on 1 side?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #2 on: September 21, 2022, 11:04:06 am »
Are you running non-standard sized discs?
Offline NorthWest
  • 2007 GTI
« Reply #3 on: September 21, 2022, 09:10:54 pm »
Discs are standard size . Pads been replaced and still having issues on drivers side only ..:brand new caliper aswell
Offline Carpy25
« Reply #4 on: September 21, 2022, 10:25:30 pm »
It look like the caliper sliding in an arc ,  is the carrier at an angle on the strut ? as said the pad will wear so the face will run parallel to the disc eventually
That sounds odd written down but it’s the only thing I can think off it being
Rob
Offline mjmallia
  • -Receive: 54
« Reply #5 on: September 22, 2022, 09:23:04 am »
Check the caliper is mounted straight......that there is an even gap between the disc and caliper (top L+R and bottom L+R)
Also check the hub is level and even............when you spin the wheel in the air, is it straight?
Mike
South Coast
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #6 on: September 22, 2022, 10:46:42 am »
As above - have seen these where there is rust on the hub faces where the caliper carrier sits , so when bolted up it sits on the pi55.
