Author Topic: New here from Scotland  (Read 10707 times)
Offline Dogg1210
Re: New here from Scotland
« Reply #30 on: October 07, 2022, 07:41:14 pm »
Decent tyres help. And feed the throttle in gently until the car has enough momentum to mash the pedal down, which helps with wheel hop and one tyre fires.
Eagle F1 SuperSport has been the best tyre for me so far in terms of traction, but when they're worn down to 3mm remaining, the tramlining is unbearable.
Cheers sure it's ps4 on front
Offline SANDEGTI
« Reply #31 on: October 07, 2022, 07:51:01 pm »
Same here, still need to get the backs done though. Not sure what to go with...
It made a massive difference in the summer though, before it was just spinning through every gear. I couldn't even make out the names of them so must have been dodgy  :driver:
Stage 2+ 2005 Laser Blue
Offline Dogg1210
« Reply #32 on: October 07, 2022, 09:10:26 pm »
  little sound clip of exhaust
Offline Dogg1210
« Reply #33 on: October 08, 2022, 01:02:12 pm »
Wee clean today
« Reply #34 on: October 08, 2022, 08:40:49 pm »
looking good
Offline Dogg1210
« Reply #35 on: October 11, 2022, 07:38:04 am »
Anyone any idea how much these are worth ? Got the false floor ith the car but I needed my rear seats in
Offline katiemolina43
« Reply #36 on: October 13, 2022, 01:13:36 pm »
welcome  :happy2:
Offline Dogg1210
« Reply #37 on: October 16, 2022, 07:52:58 pm »
Little clean today and fitted a sunstrip
Offline Dogg1210
« Reply #38 on: October 16, 2022, 07:54:34 pm »
What do I need for a k04 swap car has full exhaust oversized ram Air induction r8 coil packs I have a stage 2 twin plate clutch but not fitted.
Offline SANDEGTI
« Reply #39 on: October 16, 2022, 08:50:21 pm »
k04-064 Turbo Charger & Injector Setup from above
Upgrade HPFP – (High Pressure Fuel pump)
RS4  FRPV 136BAR (FuelRail Pressure Valve)
200bar Fuel Rail Pressure Sensor (we will supply and fit this item during mapping)
3 Bar Map Sensor (we will supply and fit this item during mapping)
Full Performance Sports cat or Decat Exhaust System
Upgrade Front Mount Intercooler
High Flow Cold Air Induction Kit
Offline breeze
« Reply #40 on: October 17, 2022, 06:33:46 am »
It depends on your power and torque goals. You could fit the turbo and nothing else (apart from basic plumbing), even retaining stock injectors.
Offline Dogg1210
« Reply #41 on: October 26, 2022, 08:29:04 pm »
So coolant is spraying out my golf lol does anyone know the part number for the plastic radiator hose connection
Offline Dogg1210
« Reply #42 on: October 26, 2022, 08:44:46 pm »
It's all good found it don't think its gti specific think there all the same on the mk5 I could be wrong tho
Offline Dogg1210
« Reply #43 on: October 26, 2022, 08:46:38 pm »
Offline Dogg1210
« Reply #44 on: October 26, 2022, 08:47:33 pm »
Maybe better with this one
