Author Topic: Boost loss / noise when losing boost  (Read 774 times)
Offline MK5GTIinside
  • Newbie
« on: October 24, 2022, 08:14:08 pm »
So recently my MK5 GTI 05 when i give it some it will start to hesitates could range from 40mph upto 80mph- a noise like a screaming cat stuck in the bonnet and loss of boost for a few seconds then comes back on boost the noise appears when it hesitates and doesn't boost for a few seconds anyone any ideas?
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vj2v35qijm58fb0on26edj8j5b&/topic,131272.0.html
Re: Boost loss / noise when losing boost
« Reply #1 on: October 26, 2022, 12:15:36 pm »
Some possibilities that come to mind:
Diverter Valve - very common boost leak point for these engines, it's happened to most of us
Rocker cover gasket - less common but can be the cause, if it's really oily by the rocker cover seal then could be this
Offline mjmallia
  • -Receive: 54
« Reply #2 on: October 26, 2022, 12:24:40 pm »
A split DV will make a louder than normal pssssst! noise, almost like a blow off valve.......no boost all the time, or at least very little with the car driving like a NA 2.0
Screaming or screeching......sounds like a turbo issue to me.....the blades hitting the walls of the housing.
Mike
South Coast
Offline Fallout-NL
« Reply #3 on: October 26, 2022, 04:17:38 pm »
Is the wastegate actuator ever known to cause issues like this on Mk5 GTI's?
I've recently replaced my DV, which improved the boost situation, but there's still times where I suspect I'm losing boost somewhere. Especially if I start accelerating from lower in the rev range, or at least, it seems that way.
  • Newbie
« Reply #4 on: October 30, 2022, 03:30:22 pm »
Ye it sounds more like a screaming / screeching noise like you mentioned. more than any pssssst noise. may have to get it into a garage asap
