Author Topic: Engine Cutout - VCDS Codes  (Read 856 times)
Offline Numero9
« on: November 20, 2022, 01:20:55 pm »
Car (08, manual GTI) has been running okay but on a recept shopping run car started to lose all power & EPC light came one. Turned the car off and on, light disappeared and drove fine. On return journey happened again twice. Cleared the codes and ran it again, following codes came back:
License Plate: GTI
Mileage: 175820km-109249mi   Repair Order:
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1K0 907 115 Q    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 0403000318070060
            Work Shop Code: WSC 08708 803 00000
                      VCID: 346742E5572A332D97-8060
2 Faults Found:
004917 - Engine Torque Monitor 2
               P1335 - 008 - Control Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 175815 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:35:59
             Freeze Frame:
                    RPM: 2282 /min
                    Load: 58.0 %
                    Speed: 62.0 km/h
                    Temperature: 91.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
000136 - Fuel Rail/System Pressure
               P0088 - 001 - Too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 175823 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:11:11
             Freeze Frame:
                    RPM: 1784 /min
                    Load: 27.4 %
                    Speed: 48.0 km/h
                    Temperature: 91.0°C
                    Temperature: 16.0°C
                    Voltage: 14.224 V
Work I have done on it since I've had it:
New temp sensor
New cam follower & o-ring
New thermostat
It already had an aftermarket Ram air filter.
- I've checked the throttle pedal and its smooth from 0% and goes to 99.6%, returns fine.
- I've gone through some of the other measurement block and they appear to be okay but I'm not sure what the baseline should be i.e. fuel pressure was around 4bar
- Every now and again there is a misfire but it's not long or frequent enough to log an error code
Any advice or guidance on what this could be?
« Last Edit: November 20, 2022, 01:26:15 pm by Numero9 »
Offline Numero9
Re: Engine Cutout - VCDS Codes
« Reply #1 on: November 22, 2022, 01:33:12 pm »
anybody?
