Author Topic: Washer Fluid Level Sensor  (Read 1905 times)
Offline Sie
« on: April 03, 2010, 10:29:30 am »
Since i got the car, this item hasnt work. Was wondering if anyone else has had a problem with there?? Also is access to the bottle a bumper off job or can  you get at it through the arch liner and under tray, was thinking of check to see if there is voltage at the plug and then could count it as being a duff sensor??
Sie
Fettled Laser Blue '05 GTi 5dr
Nasir
Re: Washer Fluid Level Sensor
« Reply #1 on: April 03, 2010, 11:21:29 am »
Do you have the winter pack? (heated washer jets, headlight washers, heated seats and low washer fluid warning). If you don't then there is no sensor.
Offline Sie
« Reply #2 on: April 03, 2010, 02:03:20 pm »
No i havent, just thought it was a standard item had it in my GT TDi MK4, that didnt have the winter pack either.
No way, thanks
Sie
Nasir
« Reply #3 on: April 03, 2010, 03:02:46 pm »
Yes welcome to the Mk5 cost cutting :signLOL:
