Author Topic: Heating/AC and ECON only blows full hot or warm.  (Read 650 times)
Offline ksamyui
« on: December 17, 2022, 11:14:55 pm »
Bit of a weird one - haven’t had the car long - but unless I put the heating on LOW, it always blows hot regardless of the temp I set, Econ on econ off.
I know it’s low on refrigerant as there’s a VCDS print out in the files that says so. I would have thought though that even if the air con is knackered, I might be able to have a little bit more control than Full Hot or Cold?
Any thoughts? I’ve got VCDS set up but haven’t had a chance to learn it, so any help there much appreciated.
« Last Edit: January 07, 2023, 08:54:22 pm by ksamyui »
Offline ksamyui
Re: Heating/AC only blows full hot or humid cold.
« Reply #1 on: January 07, 2023, 08:53:31 pm »
Cooling fans on radiator also don’t seem to come on. I’m going to run the output test on VCDS tomorrow to check they’re working; I read on another forum that the fan not working can stop the air con
https://www.vwaudiforum.co.uk/forum/showthread.php/120004-No-AIR-CON-Chilling-Both-Rad-Fans-never-run-MK5-Golf-2005-55-plate
« Last Edit: January 07, 2023, 08:55:11 pm by ksamyui »
