Author Topic: P0234 Overboost issue  (Read 1110 times)
Offline adamvaughan
« on: December 22, 2022, 04:53:00 pm »
Hello. I wonder if you can offer any thoughts on the issue I'm having with my 2.0 TSI Mk5 estate (BWA engine).
For context - It's a Japanese import and I haven't driven it a great deal since it landed. on first driving it would flash the engine light and go into limp mode when putting your foot down. Fault codes at the time saud coil pack so I replaced these on cylinders 1 & 2 (there was corrosion on the end of them).
Now it's still going into limp mode when you put your foot down. All boost drops off around 4000rpm and the fault code I'm getting says P0234 overboost condition. [
I've taken it to a couple of places to look at it. The first place replaced the MAF sensor and this didn't solve it. They then told me it likely needed a new turbo (£1600).I was reluctant to take them up on this as they were talking about vanes sticking in the turbo. I understood this was only an issue for the kind of turbos fitted to TDIs, is this correct?
The second place replaced the N75 valve and this hasn't solved it either.
I've pasted a couple of scans from below. The first is after the first place looked at it, the second after the second place. I've noticed now there is a fault code related to the MAF and one related to voltage. Could it be a voltage issue to the MAF sensor causing the problem? Where would I start in addressing this?
Any help is much appreciated
Code: [Select]
Sunday,04,December,2022,12:19:05:15724
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ9M256056   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9Mxxxxx   Mileage: 65860km-40923miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0020
   Revision: 5BH16---    Serial number: VWXBZ0I0020782
   Coding: 040300431C070160
   Shop #: WSC 01668 000 00000
   VCID: 343112AB5238B96B33B-8060
   VINID: 9E69EAAAA05BA89742146005181A2626EF
1 Fault Found:
000564 - Boost Pressure Regulation
               P0234 - 001 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 65854 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:43:24
             Freeze Frame:
                    RPM: 2385 /min
                    Load: 95.3 %
                    Speed: 81.0 km/h
                    Temperature: 57.0∞C
                    Temperature: 14.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1817
   Revision: 04843012    Serial number: 00000805030151
   Coding: 0000020
   Shop #: WSC 00066 000 00000
   VCID: 1373B13737765E534A1-8046
No fault code found.
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 133B600D09270000C80B06E9901F0081B500
   Shop #: WSC 21882 003 1048576
   VCID: 00598E7B5A00D5CBE73-8054
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 68
                    Mileage: 65720 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 2
                    Count: 12
                    Count: 13056
                    Count: 8193
                    Count: 42496
                    Count: 65280
                    Count: 0
                    Count: 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 7BA3F9973FE6B613B21-802E
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
01592 - Air Quality Sensor (G238)
            014 - Defective
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000000986246
   Coding: E78F0F2700041500470000001C00000000097F075C000120000000000000
   VCID: 71BFDBBF6DAACC4318D-8024
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 030708 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     200508 046  0204
   Coding: 00208933
   Shop #: WSC 00066
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AB    HW: 1K0 909 605 AB
   Component: 7F AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M05S52$
   Coding: 0014150
   VCID: 6C81CACB4A8821AB2BB-8038
   Subsystem 1 - Serial number: 6332MSME33214B3CA
   Subsystem 2 - Serial number: 6342MSME3A23060A6
   Subsystem 3 - Serial number: 6351HSME165109571
   Subsystem 4 - Serial number: 6361HSME162733651
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           051 0101
   Coding: 0012142
   VCID: 0451826B4218C9EBC3B-8050
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
5 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
            012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 864 A    HW: 1K0 920 864 A
   Component: KOMBIINSTRUMENT YJU 3905
   Revision: V0010000    Serial number: VWXBZ0I0020782
   Coding: 0007403
   Shop #: WSC 15171 067 57207
   VCID: 2A0D0CD380FCFF9B997-807E
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 200508F2001609
   Coding: ED817F060002022003
   VCID: 35372FAF5942A063045-8060
2 Faults Found:
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 68
                    Time Indication: 0
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 28
                    Mileage: 65688 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:10:15
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO YJU            3905
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000083388612
   Coding: 0004790
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
1 Fault Found:
00750 - Warning Lamp
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 10.50 V
                        PD
                    Temperature: 17.0∞C
                    RPM: 234 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 8090020052830C7F2D0484056008DF03E0FCA0
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 67
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1520
   Revision: 71009005    Serial number: 00000530088610
   Coding: 0005046
   VCID: 72BDD4B368ACF75BE17-8026
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: 74B1D2AB12B8F96BF3B-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003251623
   Coding: 0000144
   VCID: 75B7EFAF19C2E063C45-8020
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003204011
   Coding: 0000144
   VCID: 76B5E8A304C4EB7BCDF-8022
End----(Elapsed Time: 01:18, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Code: [Select]
Thursday,22,December,2022,16:08:46:15724
www.Ross-Tech.com
VIN: WVWZZZ1xxxxx   License Plate:
Mileage: 65900km-40948mi   Repair Order:
VIN: WVWZZZ1KZ9M256056   Mileage: 65900km-40948miles
42-Door Elect, Driver -- Status: Malfunction 0010
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 65854 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:43:24
             Freeze Frame:
                    RPM: 3347 /min
                    Load: 100.0 %
                    Speed: 65.0 km/h
                    Temperature: 33.0∞C
                    Temperature: 3.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 65880 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 137 /min
                    Load: 73.7 %
                    Speed: 0.0 km/h
                    Temperature: 20.0∞C
                    Temperature: 12.0∞C
                    Voltage: 9.652 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0100 0100
   Coding: 0000020
   Revision: 00H45001
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 68
                    Mileage: 65720 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 2
                    Count: 12
                    Count: 13056
                    Count: 8193
                    Count: 42496
                    Count: 65280
                    Count: 0
                    Count: 0
2 Faults Found:
            014 - Defective - Intermittent
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 00208933
   Shop #: WSC 00066
   Coding: 0014150
   Coding: 0012142
5 Faults Found:
00576 - Terminal 15
   Coding: 0007403
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 68
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 29
                    Mileage: 65688 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:10:15
   Coding: 0004790
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 0 km
                    Time Indication: 0
   Revision: 00H15000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 10.50 V
                        PD
                    Temperature: 17.0∞C
                    RPM: 234 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 67
                    Time Indication: 0
   Coding: 0005046
   Coding: 0000003
Address 56: Radio
Cannot be reached
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:19, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Offline mk5gtibwa
Re: P0234 Overboost issue
« Reply #1 on: December 29, 2022, 11:24:40 pm »
I've been also getting limp mode and the same error code P0234 overboost condition however have not had any error codes to do with MAF sensor or voltage, I'm planning on replacing the N75 as I have also received an error code for the N75 (P0243 - Solenoid Valve (A) for Boost Pressure Control (N75), Open / Short Circuit to Ground) as well as the diverter valve. If that doesn't work I'm not sure what to try next as a new turbo will be too expensive atm.
Offline mk5gtibwa
« Reply #2 on: January 18, 2023, 06:11:59 pm »
Replaced N75 and Diverter valve but still getting the overboost I think the turbos must be finished 😭
