Author Topic: Air con pressure sensor, getting the electrical connector off  (Read 492 times)
Offline ksamyui
« on: January 01, 2023, 01:36:04 pm »
Been trying to change my AC pressure sensor this morn, but access is super tight.
I can’t get enough space/figure out how to get the electrical connector off, any tips?
« Last Edit: January 01, 2023, 01:45:32 pm by ksamyui »
Offline Jons1001
Re: Air con pressure sensor, getting the electrical connector off
« Reply #1 on: January 01, 2023, 08:35:02 pm »
Think easiest way is using a 17mm crows foot spanner . Heres an old post i found on the forum;
https://www.mk5golfgti.co.uk/forum/index.php/topic,99478.0.html
Offline ksamyui
« Reply #2 on: January 01, 2023, 10:03:50 pm »
Cheers; yeah saw that one. It's not so much getting the thing out, it's just getting the electrical connector off so I can unscrew the sensor. I can barely get my hand down to the sensor, let alone press any tabs. Thinking at the moment that if I undo the sensor 1/4 turn, I might be able to get slightly better access to the electrical connector's clip.  :thinking:
