Author Topic: front door  (Read 800 times)
Offline matty34
  • My Ride: mk5 gti 2006
front door
« on: January 04, 2023, 09:09:17 pm »
hi im matt been a golf fan all my life from mk1,2,5's many convertibles as well,i have a mk5 4 door gti completley standard and love it,someone decided to drive into my passenger front door and drive away,question is will any mk5 door fit none gti ? cheers for info matt
hhjk
Offline mjmallia
  • -Receive: 57
Re: front door
« Reply #1 on: January 05, 2023, 10:41:55 am »
As long as the other car has the same number of doors, then either door or even just the outer door skins are transferable
Mike
South Coast
Offline matty34
Re: front door
« Reply #2 on: January 05, 2023, 06:31:28 pm »
cheers for infor any other 5 door vw's jetta's etc
hhjk
Offline DBXdarkangel
  • -Given: 18
Re: front door
« Reply #3 on: January 05, 2023, 07:39:04 pm »
Just get a door skin off fleabay for like £60. Easy to fit.
Offline matty34
Re: front door
« Reply #4 on: January 05, 2023, 08:29:16 pm »
been trying nothing close to me at the momment,went to see repair shop he said a complete door best way as the crash bar maybe broken?? no idea what that ment.
hhjk
Offline mjmallia
  • -Receive: 57
Re: front door
« Reply #5 on: January 06, 2023, 08:05:55 am »
Check for yourself the crash bar and make the decision.
Here is the guide on the skin removal
https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/97-BODY-Removing_Your_Front_Door_Skins/97-BODY-Removing_Your_Front_Door_Skins.htm
The crash bar if damaged is replaceable as it simply unbolts
Mike
South Coast
Offline Uncleben
Re: front door
« Reply #6 on: January 06, 2023, 08:06:48 am »
Depends how bad the damage is, behind the door skin is a reinfored bar called the crash bar, if this is damaged it can be replaced as it is only a bolt on part, the door skins on mk5 golfs are also removeable, loads of t30 torx bolts so if the door frame is ok you can just replace this.
Jetta and golf estate door skins are different however, they have an additional swage line above the handle and a different shape at the bottom.
Offline matty34
Re: front door
« Reply #7 on: January 06, 2023, 04:48:00 pm »
thanks all for info will look foor door as i know ive got everything then,anyone know a good reliable vw breakers?
hhjk
