Author Topic: Cambelt and timing chain  (Read 467 times)
Offline frasermk5
« on: January 23, 2023, 06:14:57 pm »
My mk5 has just hit 100,000 miles, had cam belt replaced at 60k, is it worth getting the belt and chain done at the same time (does it save a bit on labour cost?) or should I prioritise one or the other at this mileage?
Re: Cambelt and timing chain
« Reply #1 on: January 24, 2023, 01:55:19 pm »
Let your wallet decide as there is little to no labour saving do both together, being at opposite ends of the engine.
Cambelt is time and/or distance, so if 60K was over 4 years ago, then you need a belt regardless.
For preventative maintenance's sake, I'd do both personally.
