Author Topic: GTI Fueling issues  (Read 881 times)
Offline bongoinvade
  • Newbie
GTI Fueling issues
« on: January 26, 2023, 07:18:32 am »
Hi guys,
So basically if I turn the car on and let it idle for a bit the engine will just shut off. It also happened once mid drive.
I scanned the car with VCDS and got these errors so any help would be great helping me try and solve the issue
4 Faults Found:\
012556 - Low Pressure Fuel Regulation \
               P310C - 004 - Fuel Pressure Drops Intermittently - Intermittent\
012403 - Fuel Pump Circuit \
               P3073 - 008 - Electrical Malfunction - Intermittent\
004195 - Fuel Pressure Regulation \
               P1063 - 002 - Control Range Not Reached - Intermittent\
012425 - Signal Line for Fuel Pump Electronics \
               P3089 - 002 - Electrical Malfunction - Intermittent\
Re: GTI Fueling issues
« Reply #1 on: January 26, 2023, 11:40:59 am »
The clues are all there in the fault codes.  Bad LPFP or bad wiring.
