Author Topic: Is it worth changing gearbox oil?  (Read 4423 times)
Offline smilespergallon
« on: January 27, 2023, 03:32:41 pm »
I've got a 57 plate Mk5 Golf GTI Edition 30. I've only ever had it serviced by independent garages, but now I'm starting to service it myself, and I'm really enjoying it.
Whilst I'm giving it a thorough service, is it worth changing the gearbox oil?
I've read that according to Volkswagen it technically never needs changing. But considering the car is 15 years old and has done 150,000 miles, I'm wondering if it might be worthwhile doing so anyway. Nothing feels wrong with the gearbox as it is, but then again I suppose I can't remember what the gear changes felt like when I first got the car years ago.
Would there be any benefit to changing it? Or am I best off just leaving it if it doesn't seem bad at the moment?
Thanks in advance!
P.S. If I do change it, is Fuchs Titan Sintofluid SAE 75W80 GL-4 Manual Transmission Fluid the correct gearbox oil?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Is it worth changing gearbox oil?
« Reply #1 on: January 27, 2023, 07:21:19 pm »
I would. I always change the gearbox oil in my cars and post change the gearshift is always better.
The colour of the used oil is always darker than the new stuff I put in. I'm not sure on which specific oil you need.
My golf is DSG and I change that oil every 2 years.
Offline Octoparrot
  • -Receive: 103
« Reply #2 on: January 27, 2023, 08:07:19 pm »
I'd use the genuine vw oil, heard bad reports about aftermarket oils. Vw stuff is expensive but it's not like you're changing it regularly like the engine oil.
Offline Grevling89
« Reply #3 on: January 27, 2023, 10:44:20 pm »
My MK5 manual says to change DSG oil every 60.000 km (every 37282.272 miles for you imperialists out there)
I've not done it on mine yet, still 5000 km or so left on the interval.
On a scale from tire kicker to Mighty Car Mods, how difficult would you say the job is? They're charging the equivalent of $450 to change it around here. Which seems, you know. A bit much if I could do it myself.
2007 MK V - Pearl Black - 5 door - Happily stock
Offline breeze
« Reply #4 on: January 28, 2023, 06:25:16 am »
Easy job on a manual. You may need a funnel and it is generally wise to remove the fill plug before removing the drain plug (to be certain you can refill).
I’d only use the genuine oil from a dealer.
At 150k with no evidence of a change I would be doing one for sure.
Offline FatWelshBoy
« Reply #5 on: January 28, 2023, 08:20:40 am »
I have a manual and changed the gearbox oil at 80k, no difference at all afterwards. The oil that came out was slightly darker than the new stuff but driving the car is exactly the same as before. I didn't buy the current gearbox oil, I asked the VW parts desk for the part number of the oil from previous revisions and bought that off ebay at £65 for 3 litres. The stuff I put in is what my car left the factory with according to VW, although Coverdale say the gearbox oil in a Ed30 is different to the mk5 gti?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #6 on: January 28, 2023, 01:47:47 pm »
i'd say it's only slightly more involved than changing your engine oil, and that's due to how you fill the gearbox back up. It's deffo a DIY job and once you've done it you'll never have to pay for someone else to do it.
Here's a guide.
https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/69-TRANS-DSG_Transmission_Oil_and_Filter_Replacement/69-TRANS-DSG_Transmission_Oil_and_Filter_Replacement.htm
Offline colesey
  • -Receive: 89
« Reply #7 on: January 28, 2023, 07:43:16 pm »
I have owned my car from new and changed the gear oil twice. The shift in cold weather was awful with the original factory oil, thick as treacle and always graunchy / slow synchro into second when warm. Will get better (after your warranty expires…) said the local dealer. Changed it to Millers nt gear oil a few years later and, whilst better, the issues never went away. The following year I changed to the revised spec OEM oil and the problems disappeared. Despite the same sae rating, this oil is as thin as piss when you pour it. Expensive, but cheaper than doing the job twice.
Offline G-olf
« Reply #8 on: January 29, 2023, 08:42:24 am »
Hi,
I changed the oil in mine a while back there was no evidence it had ever been changed in its lifetime.
There were 2 types of genuine oil listed at the time but it was difficult to find out the differences between the 2.
This one went in G 052527 A2 which was the recommended oil by my dealer.
I bought a new filler plug because sometimes they can be hard to remove ( it came out fine, allen key type)
From memory It took approx 2.1 litres to start to show on the level bung with the car jacked up level front to back and sides, similar to what came out.
I used a sealey transfer gun, suck out of bottle and squirt in gearbox.
As breeze said, undo the level bung first so you know you can re-fill
It shifted nice before and continues to after, only changed for maintenance.  :happy2:
« Reply #9 on: February 04, 2023, 07:41:27 pm »
Thanks everyone for the advice.
I ended up using Fuchs Titan Sintofluid 75W80 gearbox oil. This was £40 for 3 litres off eBay, whereas getting the OEM oil from somewhere like darksidedevelopments.co.uk was more like £110 for 3 litres (https://www.darksidedevelopments.co.uk/products/genuine-vw-transmission-oil-g-052-911-a2.html). I read around the Internet that Fuchs Titan Sintofluid was the same as OEM rebranded. A lot of people just said to stick with OEM, but I couldn't find anywhere that said that Fuchs was bad in any way, so I thought I'd give it a go.
It looked to be about the same consistency. Very thin. I think the oil already in the gearbox might have been slightly thinner, but then again it was hot when it came out so it's not a fair comparison. Either way it didn't look too far off.
The oil that came out of the gearbox was pretty dark, as expected.
I've been driving the car with the new oil for a couple of days now. The gearbox feels absolutely fine. Nothing suggests to me so far that the Fuchs Titan Sintofluid 75W80 was the wrong oil to use. I wouldn't say changing the oil has made a massive difference. Possibly slightly smoother gear changes, but that just might be a bit of a placebo effect. Either way I'm glad I changed it.
It was real easy to change the oil as well -- just a 10mm hex/allen bolt for the fill and another 10mm allen bolt for the drain. I ended up feeding a PCV tube with a funnel attached down through the engine bay to fill up the gearbox with the new oil. About 2.2L came out, and it started to overflow after about 2.4L went in.
« Last Edit: February 04, 2023, 07:46:50 pm by smilespergallon »
Offline breeze
« Reply #10 on: February 05, 2023, 08:07:35 am »
You might find that oil is a bit harder to get into gear when very cold.
« Reply #11 on: February 06, 2023, 11:39:35 am »
More like £180 - https://www.darksidedevelopments.co.uk/products/genuine-vw-gearbox-case-oil-1-litre-g-052-527-a2-g052527a2.html
Your link isn't the most up-to-date oil.
Fuchs is one of the best manufacturers of oils in the world, so no issue there. Hardly anyone has heard of them, but they make the famous Silkolene ester racing oil, and the Quantum Platinum range.
Offline breeze
« Reply #12 on: February 06, 2023, 04:32:19 pm »
Has anybody actually used the G052527A2 £60/litre oil? I have the G052171A2 £30/litre oil in mine.
Posts that I have found:
https://bobistheoilguy.com/forums/threads/please-help-me-tell-the-difference-between-two-vw-manual-trans-oils.339444/
https://uk-polos.net/viewtopic.php?t=78026
https://www.mk5golfgti.co.uk/forum/index.php?topic=131783.0
That makes me think I should be fine on the earlier formula, unless somebody can explain what the real world difference is (it looks like there is a small difference in warm viscosity).
« Last Edit: February 06, 2023, 04:41:13 pm by breeze »
Offline FatWelshBoy
« Reply #13 on: February 06, 2023, 06:46:40 pm »
I used G052171A2 when I did my gearbox oil. VW parts desk said its perfectly fine to use and likely what was already in my gearbox. I've an Ed30 and for some reason Coverdale specifically state ****THIS OIL IS NOT FOR S3 8P MANUAL, MK5 ED30, VRS OR CUPRA R**** but I can't see what's different between a GTI and Ed30 gearbox, the S3 gearbox I can understand possibly needing a different oil? Anyway, I changed the gearbox oil with G052171A2 and there's no difference whatsoever, no cold or hot shifting issues so perfectly happy with my choice and was pretty cheap from an ebay seller.
« Reply #14 on: February 07, 2023, 10:12:41 am »
S3 has a transfer box attached to it, but that wouldn't make any difference anyway. ED30 and GTI gearboxes are identical.
I can't remember what genuine oil I used in mine last, but I certainly wouldn't have paid £180 for it  :grin:
Closest match to the OEM oil I found in terms of cold shifting performance was Redline MTL.
