Author Topic: Mk5 GTI rough idle and misfire  (Read 1470 times)
Offline Vag-mk5
« on: March 12, 2023, 08:36:07 pm »
Hello everyone, I have a problem with my gti
If the car stands still for a day and I start it, it has over 30 misfires on cylinder 4 read with VCDS
but only the first 20sec after that nothing more and it runs quietly
and as soon as the engine has reached operating temperature and i brake at traffic lights, cylinder 1 occasionally misfires when idling
so far i have changed the parts and it was still the same error
spark plugs
Ignition coils
Injectors
Compression measurement(good)
Mass airflow meter
PCV
lambda sensors
I really don't know what else to do, please help, thanks :jumping:
Offline mjmallia
  • -Receive: 54
Re: Mk5 GTI rough idle and misfire
« Reply #1 on: March 13, 2023, 10:15:06 am »
The small cam chain and its tensioner.....also the three plastic rings in for the oil pressure to the actuator can all create misfires and rattles.
Mike
South Coast
Offline Vag-mk5
« Reply #2 on: March 13, 2023, 10:26:13 am »
Yes, the chain and tensioner were also changed 2 weeks ago
And the 3 rings from the housing also changed
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #3 on: March 13, 2023, 09:21:32 pm »
Any coolant loss/signs of coolant on spark plugs?
Offline Vag-mk5
« Reply #4 on: March 13, 2023, 09:52:32 pm »
no, there is no loss of coolant or it is not noticeable, I changed it completely a year ago and the level is still between min and max
Offline Marky050618
« Reply #5 on: April 17, 2023, 06:18:47 pm »
I done my chain a couple weeks back then had this, was driving me potty turnt out the middle of the three rings in that housing broke and cam out and i didn't notice which caused this issue.
Offline DDale
« Reply #6 on: June 18, 2023, 01:03:21 pm »
Had the same symptoms before, especially the misfires on stop. It ended up being the N80 Purge Valve so might be a good thing to check.
https://www.mk5golfgti.co.uk/forum/index.php?topic=132469.0
