Author Topic: Coolant stop once a week can't find leak  (Read 567 times)
Offline Beanmk5
« on: March 16, 2023, 06:41:34 pm »
Been getting a STOP coolant warming once a week and just been filling with water, obv with weather changing I want to get some antifreeze in but wanted to find leak and fix it
Ordered some of this stuff, u put it in coolant tank and run car then shine uv torch and it glows like a glow stick but can't see no drips or any sign of a leak
So now I'm baffled
Only thing I have noticed when it says stop coolant low is the screw on cap isn't tight any more so bought new cap and still have same issue
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Coolant stop once a week can't find leak
« Reply #1 on: March 16, 2023, 07:53:53 pm »
Some garages will have a coolant system pressure tester, to pressurise the system to show up leaks
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #2 on: March 17, 2023, 11:24:06 am »
This test found a tiny crack in a coolant flange that was the cause if my mk4 losing coolant. The test only took them 20 mins.
Offline breeze
« Reply #3 on: March 17, 2023, 02:00:36 pm »
Depending on how affordable your garage is, it may be worth buying a pressure testing kit on Amazon. They are not expensive, just a pump with a pressure gauge and a couple of adapters.
