Author Topic: Best tyres for grip for high HP  (Read 965 times)
Offline 09Pirelli
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=hejaluqogg7au45bpf7talpu50&/topic,133619.0.html
« on: May 01, 2023, 01:54:04 am »
Hi all, looking at getting tyres what are your recommendations for tyres im looking at potenza Adrenalins.
nothing to expensive. car is making over 350hp so need something to grip.
2009 Pirelli Edition Stage 2+
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=hejaluqogg7au45bpf7talpu50&/topic,131272.0.html
Re: Best tyres for grip for high HP
« Reply #1 on: May 01, 2023, 04:43:53 am »
This should have everything you need to know to make a decision.
https://www.tyrereviews.com/Article/2022-Tyre-Reviews-UHP-Summer-Tyre-Test.htmision for various budgets..
Offline skkane
« Reply #2 on: May 01, 2023, 11:24:27 am »
Heard Nankang AR-1's are pretty sweet. NS2Rs can also work if you're on a budget.
2007 ED30
Offline Marticus
« Reply #3 on: May 01, 2023, 12:11:37 pm »
This the the website I was using, they also have a good youtube channel with reviews.
Based on what I read there I went for hankook ventus s1 evo3, as it seems to have the best short term cost / performance where I'm buying. The downside is the longterm wear isn't great.
« Last Edit: May 01, 2023, 12:13:09 pm by Marticus »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #4 on: May 03, 2023, 04:35:31 pm »
I think you will be happy with the one in "09Pirelli."
I use Pirelli PZ4...I've seen a number of test results where it outperforms (overall) tires like Michelin PS4S and Hankook Ventus S1 EVO3.
Here the PZ4 cost $178usd/ea for a 225/40-18. When, in the same size: Hankook Ventus S1 EVO3 is $249, and Michelin PS4S is $222.
Not saying, myself, they are better...as I haven't tested them all. Just saying what I found in looking at test results, and to say I am happy with them. They also do well on wet surfaces, and I live in the wet zone in the Pacific NW (NW Oregon).
« Last Edit: May 03, 2023, 04:53:07 pm by ROH ECHT »
Offline FatWelshBoy
« Reply #5 on: May 03, 2023, 08:49:23 pm »
Unless going semi slick I think you'll struggle with any tyre, my PS5 were great at stage 1 but at 2+ they spin up for fun.
Offline Clarkj93
« Reply #6 on: May 03, 2023, 09:03:38 pm »
Would probably agree with the above! Ns2r's are a good road based semi slick so they work well from cold but work best after a little bit of driving or 1 lap or so of a circuit.
Consider playing with tyre pressures too/instead but use an accurate tyre pressure gauge not just the tyre inflator which are usually massively inaccurate. Somewhere between 30-34 cold is probably going to be the sweet spot.
Offline breeze
« Reply #7 on: May 04, 2023, 12:03:17 pm »
Have you got an anti-lift kit fitted? Probably more important than the difference between good and great tyres.
Edit: LSD/Quaife type diff also great but significantly more expensive. For the most part I think you need to adapt your driving style with a powerful FWD car.
« Last Edit: May 04, 2023, 01:13:00 pm by breeze »
« Reply #8 on: May 04, 2023, 01:05:21 pm »
Yep. Tyres are for grip. 4WD, LSDs and TC are for traction.
