Author Topic: vis hpfp tool  (Read 555 times)
Offline 9MAK
  • My Ride: ed30
vis hpfp tool
« on: May 11, 2023, 04:05:50 am »
Hi, does anyone know where i can get this tool for fitting vis hpfp because im removing it from my old hpfp and installing it into a new one.
Offline 09Pirelli
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=m90iia9fe63f84knpi5jd1cid8&/topic,133619.0.html
Re: vis hpfp tool
« Reply #1 on: May 11, 2023, 05:57:16 am »
i think you can get it from VIS if you really want it, i installed mine without the tool its not that hard to just use your hands and push
2009 Pirelli Edition Stage 2+
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: vis hpfp tool
« Reply #2 on: May 11, 2023, 05:17:42 pm »
Yes, there's other ways to get it done.
Since you need a vise, or something similar to work with when using the tool, you can make your own from metal and measure and cut your own slot into it....or just use two pieces of straight metal (same thickness) across the opening of a vise or two boards of lumber. You can use a socket, that will clear the center button, to tap the cap down for removing it from the OE piston; once you've separated the OE piston from all else but the cap;
« Last Edit: May 11, 2023, 05:22:22 pm by ROH ECHT »
