Author Topic: RHD MK5 Brake Servo Replacement  (Read 2002 times)
Offline Nathanwalsh182
  • Newbie
« on: June 04, 2023, 08:51:16 pm »
Anyone attempted changing the brake servo on their MK5? Bought a PD170 with a braking issue that is being caused by the servo. Looks like a terrible job! Has anyone got any tips/tricks?
Re: RHD MK5 Brake Servo Replacement
« Reply #1 on: June 05, 2023, 11:21:41 am »
Engine needs to move out of the way on the driver's side.......so it's mount off, downpipe detached, fuel lines detached, driveshaft detached etc.... then move the engine forwards with a hoist.
Once that's done, it's just a case of unclipping the pedal from the master cylinder (there's a special tool for it, but most people make do with a screwdriver) and removing the brake lines from the Master cylinder, unbolt the servo etc, then pull it out.
It's not as bad as it sounds.  Just need the right tools.
  • Newbie
« Reply #2 on: June 05, 2023, 09:23:44 pm »
Ah that doesn’t sound so bad! Doing it on the floor so hopefully won’t take too long!
