Author Topic: Fitting highline clocks, cruise control & steering wheel buttons on a 56 plate d  (Read 453 times)
Offline Lewo
As above.
Standard 56 plate dsg gti.
Any other bits needed?
Would need to pay to get these fitted, any idea of how long to fit and if anyone knows of a place in Kent that would be helpful cheers
Offline fakie1977
Can’t help you with somebody in Kent area but I paid someone to retrofit highline and cruise control in Midlands area. Took no more than about an hour if I remember right. He also supplied all the parts needed which was just the clock and stalk.
I also retrofitted steering wheel buttons but this was easy if you have DSG and the steering wheel paddles already as the wires and space are already there. Just need to take airbag off and unscrew the blanking plates, and screw in and plug in wire for the buttons in its place. Lots of how to around. If you don’t have the paddles it’s not an easy process. You need to hack out the area where the buttons go. Not sure about wiring though.
Offline Lewo
Ok thanks, will have a look to see if there's any guides on here & Youtube for fitting the stalk when I can.
Buying another wheel with the buttons already fitted now so will get a garage to fit this & the clocks.
I've read somewhere about maybe having to change the slip ring, whatever that is ....?  :signLOL:
