Hey guys,
I'm looking at parting with my STG3 ED30, and would value opinions as to what its worth. Spec and mods below
Spec
Black 5dr DSG
165k miles
4 previous owners 3rd had car for 4 years, 4th for 7 years, I have owned for 2.5yrs
May 2008 Registered
Build number 2198
No rust anywhere
Bodywork in immaculate condition given the age and mileage and has been detailed and ceramic coated by me as I am a part time detailer.
Arch liners were removed, and all minor surface rust treated, then sprayed with Hammerite.
Interior is again very clean, but the usual drivers seat bolster issue, and has slight tare
Service history is part VW part Indie, with a box folder full of bills etc
DSG box fully rebuilt by Milta Technology Aug 2021 @ 152k
STG3 venom 450 Hybrid conversion carried out by R-Tech Feb 2022 @155k miles - 433hp 412tq (bills & graphs to prove from R-tech will be supplied)
DSG map by Niki @ R-Tech with increased clamping pressures
The following work/fitting was also carried out a the same time
REVO induction kit
New Thermostat
Runner flap delete
Inlet walnut blast clean
New camchain/tensioner
Oil sump and pick up pipe cleaned and refreshed
VIS Balance shaft delete
Trackslag 90mm de-cat DP
New Coil packs
New rocker cover gasket
4xNGK BKR 7eix spark plugs
Custom BCS resonated non valved sports exhaust
Other Mods
Airtec STG3 I/C
Brand new fan pack
Brand new AC condenser (Freezing A/C)
Fully reconditioned S3 front calipers with Brembo 345mm drilled/grooved discs and pads fitted @164k miles
New rear calipers with brembo drilled/groved discs & pads
Custom Xenon headlights from Tim Russell @ Golfskylinemods
New front bumper
Tailgate window and rear door windows tinted
Black VW tailgate badge
LED number plate & reversing lights
RCD330 head unit with wireless Apple Car Play
FULL AND COMPLETE front & rear suspension overhaul, replaced with OEM parts
PowerFlex Anti Lift kit
PowerFlex Dogbone insert
New engine mounts
Passat Alloy arms
Full Hunter 4 wheel laser alignment
I've prob missed a few bits, but you get the idea. Car has had oil changes every 5k and the last owner did the same.
It drives like a new car and is Ballistically quick and a joy to drive
So people what you think its worth. Don't be put off by the mileage as Niki said the engine is in great condition due to many many 5k oil changes during its life
