Author Topic: Maf sensor wiring voltage  (Read 818 times)
Offline Multicrazy
« on: July 20, 2023, 07:02:53 pm »
Hello everyone, I have a maf sensor problem error code P0100 with my car it doesn’t connect to the maf sensor. I have a 3 wire maf sensor. 1- yellow 2- brown 3-black. Need help on how to diagnose these wires.
On 1- yellow I get 5v with ignition ON
On 2- brown if I put multimeter on continuity I get a beep
On 3- black I don’t get a beep. I’m not sure if I am doing this correctly.
My local repair shop says that my ECU is damaged because the maf sensor doesn’t have any issues and there are other ECU related fault codes 1 being which says ECU faulty coded. Could the ecu be damaged or is it just a wiring issue. If anyone can help how to diagnose the wires with a multimeter that would be really appreciated thank you so much!
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Maf sensor wiring voltage
« Reply #1 on: July 21, 2023, 02:04:39 am »
I reference voltage 5v
2 Ground
3 12v
Key on engine off!
Offline Multicrazy
« Reply #2 on: July 21, 2023, 07:09:01 am »
2 Ground
3 12v
Key on engine off!
Thank you! Will give it a go
