Author Topic: do i have the wrong centre console?  (Read 1141 times)
Offline Russboy
« on: July 23, 2023, 12:34:27 pm »
I have a 56 plate gti and so the subject says im not sure if i have the correct centre console,? Is there a year change that the centre console changed or has a old owner changed it for some reason?
Offline mjmallia
Re: do i have the wrong centre console?
« Reply #1 on: July 23, 2023, 12:57:50 pm »
That is the basic, no arm rest option
Mike
South Coast
Offline Sebas_theFish
« Reply #2 on: July 24, 2023, 01:56:16 am »
No, the arm rest was an option.
Offline OllieVRS
« Reply #3 on: July 24, 2023, 12:34:51 pm »
The cheaper Skoda Octavia vRS came with an arm rest as standard, but the GTI didn't? that's surprising considering the GTI was at least £2000 dearer new, and that was back in early 2006  :surprised:
'06 Skoda Octavia vRS TFSI
Offline Russboy
« Reply #4 on: July 24, 2023, 09:12:49 pm »
Can I remove the part at the back and fit a gti centre arm rest or do I have to fit a whole new centre console?
Offline mjmallia
« Reply #5 on: July 24, 2023, 09:47:51 pm »
My GTI came like yours without an armrest. They are easy to retrofit.
You can do just the rear arm rest part, but to complete the mod properly and make the rear vents work in the arm rest, you will also need the air vent pipe that fits under the main centre console section. It will connect to the a blanked off hose up behind the Ash tray area and the other end to a pipe in the arm rest if left not taken out already.
Mike
South Coast
Offline mjmallia
« Reply #6 on: July 24, 2023, 09:54:44 pm »
This may help
https://www.myturbodiesel.com/d2/1000q/a5/center-console-removal-mk5.htm
Note there are a couple of arm rest types also. One is just a cubby hole and the other allows for a cd changer or MDI unit which is what I opted for with my RCD510 DAB. The MDI unit also has a small storage area
Mike
South Coast
Offline Dogg1210
Offline Russboy
« Reply #8 on: August 09, 2023, 11:05:43 am »
I already have a damaged one of those aftermarket arm rests in the boot from the last owner. I was just seeing what I could do or if he had knackered part of the arm rest at some time and fitted a standard one in?
