Author Topic: Front brake upgrade to fit 17' monzas  (Read 666 times)
Offline DurinsBane117
« on: September 12, 2023, 07:27:59 pm »
Just went stage 1 with my gti and looking to upgrade the front brakes but will need to fit behind 17' Monzas. Wanted to fit the mk7 r brakes, anyone fitted these to 17' monzas or any suggestions for brakes that will fit?
Offline skkane
Re: Front brake upgrade to fit 17' monzas
« Reply #1 on: September 12, 2023, 07:59:54 pm »
MK7 PP brakes should fit with the 340mm discs, plug and play. I have them on mine but have the ED30 18s. I'm 90% sure they fit the 17s as you can get 17s on the GTI PP I believe.
2007 ED30
Offline akbarirfan
  • -Given: 81
« Reply #2 on: September 14, 2023, 07:01:06 pm »
100% will fit, running GTI PP fronts on mine with 17" Monzas
« Reply #3 on: September 14, 2023, 07:04:19 pm »
Thanks mate, I'm looking around to see if I can find a decent set 👌🏾 did u keep the stock brakes on the rear or did u upgrade them too?
Offline akbarirfan
  • -Given: 81
« Reply #4 on: September 15, 2023, 07:45:30 am »
Hello,
I've still got the stock rear brakes in place - not sure they are worth upgrading to be honest. I have considered it a few times but had new discs and pads 6,000 miles ago on the rear so doesn't make sense!!
The fronts however are a vast improvement.
