Author Topic: 2008 Golf GTI MK5 Stage 3 K04 Conversion DV Relocation  (Read 609 times)
Offline K03MK5
« on: September 25, 2023, 11:38:12 pm »
Hi all,  Just ordered a revo intake for the GTI with a k04 exit as I’m in the process of doing the k04 conversion.  I have the forge dv relocation pipe etc.  Any instructions on how to fit this and where to mount the divertor valve etc? Also if I need any more parts for the relocate.  Tia.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: 2008 Golf GTI MK5 Stage 3 K04 Conversion DV Relocation
« Reply #1 on: September 26, 2023, 04:28:41 pm »
The Forge kit (I can no longer find to be available) should come with everything except for the throttle-body inlet pipe necessary for the DV relocation.
Whether it's OEM or aftermarket, it needs to have this port (circled) to connect the DV adapter to using a short hose...and then a longer hose goes from the DV to the inlet port on the REVO intake.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #2 on: September 26, 2023, 04:38:16 pm »
This shows locations and it also requires the extended DV's wiring loom/harness;
« Last Edit: September 26, 2023, 04:41:45 pm by ROH ECHT »
