November 25, 2024, 06:20:59 pm
All Things Mk5
Technical Workshop
Is this ok
Topic: Is this ok (Read 1123 times)
Stu9
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Is this ok
October 13, 2023, 11:13:42 am »
On the mk5 gti I need to take the fuel pump off to check the shim before getting a new one, is it ok to use the bolts as they're a one use only. I'll get a new kit but will be next week.
Octoparrot
Won't Shut up.
-Given: 8
-Receive: 102
Re: Is this ok
Reply #1 on:
October 14, 2023, 10:35:12 pm »
Yes they should be fine, just push one hand against the pump as you're loosening or tightening the bolts, don't allow the bolts to be under tension of pump spring or you could strip the threads, loosen and tighten them evenly a little at a time.
All Things Mk5
Technical Workshop
Is this ok
