Author Topic: Intermittent Cold start issue  (Read 1297 times)
Offline DurinsBane117
« on: October 18, 2023, 07:31:59 pm »
Been having intermittent issues with cold starts lately. Issue only happens on cold start if the csr has been running it will start up with no issues. I've taken a video of the cold start, please see the link below:
i=co02zAJisePxjxuN
So far I've replaced:
- Coils and spark plugs
- Fuel filter
- 4x injectors
- battery
- cam follower
- cleaned MAF and IAT sensors
Scaned the car which shows no fault codes.
Car has had a inlet clean and has a stage 1 map.
Re: Intermittent Cold start issue
« Reply #1 on: October 20, 2023, 10:35:28 pm »
Lift pump or HPFP not building pressure quickly enough.
Offline Marj
  • Newbie
« Reply #2 on: October 22, 2023, 05:30:12 pm »
I’ve got the exact same issue, have you found out what it is yet?
